Ana içeriğe geç
How to Replace the Wheels on an Office Chair
Neye ihtiyacın var
  1. How to Replace the Wheels on an Office Chair, Removing Casters: adım 1, 1 resimden 1.
    • Lay the chair down.
    • If the chair is too heavy to turn upside down, have someone help you do it.
  2. How to Replace the Wheels on an Office Chair: adım 2, 1 resimden 1.
    • Wipe the stem of the caster with a rag or paper towel to remove any dust or debris.
  3. How to Replace the Wheels on an Office Chair: adım 3, 3 resimden 1. How to Replace the Wheels on an Office Chair: adım 3, 3 resimden 2. How to Replace the Wheels on an Office Chair: adım 3, 3 resimden 3.
    • Use a flathead screwdriver in between the caster and the base of the chair to pry the wheel out of the socket.
    • Turn the screwdriver gently until the caster starts to move upwards away from the chair.
    • Try rotating the screwdriver at different angles if the caster won't come out.
  4. How to Replace the Wheels on an Office Chair: adım 4, 3 resimden 1. How to Replace the Wheels on an Office Chair: adım 4, 3 resimden 2. How to Replace the Wheels on an Office Chair: adım 4, 3 resimden 3.
    • Use a prying tool that is big enough to fit between the caster and over the stem.
    • Gently pull on the caster upwards and it should come off.
  5. How to Replace the Wheels on an Office Chair: adım 5, 2 resimden 1. How to Replace the Wheels on an Office Chair: adım 5, 2 resimden 2.
    • Measure the wheel's height and length.
    • Once you've done that, purchase your new casters.
    • Large casters(about 3"), are more durable and versatile. Twin-wheel casters are usually used in office settings.
  6. How to Replace the Wheels on an Office Chair: adım 6, 2 resimden 1. How to Replace the Wheels on an Office Chair: adım 6, 2 resimden 2.
    • Push the caster's stem into the bottom of chair leg.
    • Install the new casters.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 55
Her zaman: 6,176
