Ana içeriğe geç
How to Replace the Xbox 360 Optical Drive Belt
Neye ihtiyacın var
  1. How to Replace the Xbox 360 Optical Drive Belt, Optical Drive Belt: adım 1, 2 resimden 1. How to Replace the Xbox 360 Optical Drive Belt, Optical Drive Belt: adım 1, 2 resimden 2.
    • Remove the hard drive.
  2. How to Replace the Xbox 360 Optical Drive Belt: adım 2, 3 resimden 1. How to Replace the Xbox 360 Optical Drive Belt: adım 2, 3 resimden 2. How to Replace the Xbox 360 Optical Drive Belt: adım 2, 3 resimden 3.
    • Use a pry tool to gently remove the faceplate from the Xbox.
  3. How to Replace the Xbox 360 Optical Drive Belt: adım 3, 3 resimden 1. How to Replace the Xbox 360 Optical Drive Belt: adım 3, 3 resimden 2. How to Replace the Xbox 360 Optical Drive Belt: adım 3, 3 resimden 3.
    • Press down on the three holes as indicated to release the clips securing the base plate.
    • Remove the base plate.
    • Repeat this step on the other side.
  4. How to Replace the Xbox 360 Optical Drive Belt: adım 4, 3 resimden 1. How to Replace the Xbox 360 Optical Drive Belt: adım 4, 3 resimden 2. How to Replace the Xbox 360 Optical Drive Belt: adım 4, 3 resimden 3.
    • Repeat the previous step to remove the top plate of the Xbox.
  5. How to Replace the Xbox 360 Optical Drive Belt: adım 5, 3 resimden 1. How to Replace the Xbox 360 Optical Drive Belt: adım 5, 3 resimden 2. How to Replace the Xbox 360 Optical Drive Belt: adım 5, 3 resimden 3.
    • Gently unhook all four clips located on the front of the Xbox.
    • Take care not to break the plastic clips; it may be fragile.
  6. How to Replace the Xbox 360 Optical Drive Belt: adım 6, 3 resimden 1. How to Replace the Xbox 360 Optical Drive Belt: adım 6, 3 resimden 2. How to Replace the Xbox 360 Optical Drive Belt: adım 6, 3 resimden 3.
    • Use the flathead screwdriver to gently press down on all of the indicated indents.
    • Remove the top casing from the Xbox.
  7. How to Replace the Xbox 360 Optical Drive Belt: adım 7, 3 resimden 1. How to Replace the Xbox 360 Optical Drive Belt: adım 7, 3 resimden 2. How to Replace the Xbox 360 Optical Drive Belt: adım 7, 3 resimden 3.
    • Use the T3 Torx screwdriver to remove all six screws.
  8. How to Replace the Xbox 360 Optical Drive Belt: adım 8, 3 resimden 1. How to Replace the Xbox 360 Optical Drive Belt: adım 8, 3 resimden 2. How to Replace the Xbox 360 Optical Drive Belt: adım 8, 3 resimden 3.
    • Carefully flip over the Xbox to the other side.
    • Lift the Xbox casing off.
  9. How to Replace the Xbox 360 Optical Drive Belt: adım 9, 3 resimden 1. How to Replace the Xbox 360 Optical Drive Belt: adım 9, 3 resimden 2. How to Replace the Xbox 360 Optical Drive Belt: adım 9, 3 resimden 3.
    • Unplug the two connections in the rear of the disk drive.
  10. How to Replace the Xbox 360 Optical Drive Belt: adım 10, 3 resimden 1. How to Replace the Xbox 360 Optical Drive Belt: adım 10, 3 resimden 2. How to Replace the Xbox 360 Optical Drive Belt: adım 10, 3 resimden 3.
    • Use a flat screwdriver to remove the four screws underneath the disc drive.
    • Flip over the DVD disc drive and remove the casing.
  11. How to Replace the Xbox 360 Optical Drive Belt: adım 11, 3 resimden 1. How to Replace the Xbox 360 Optical Drive Belt: adım 11, 3 resimden 2. How to Replace the Xbox 360 Optical Drive Belt: adım 11, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Spin the located area with the flathead screwdriver to open up the disc drive.
    • Use tweezers to remove the belt drive.
  12. How to Replace the Xbox 360 Optical Drive Belt: adım 12, 3 resimden 1. How to Replace the Xbox 360 Optical Drive Belt: adım 12, 3 resimden 2. How to Replace the Xbox 360 Optical Drive Belt: adım 12, 3 resimden 3.
    • Replace with a new drive belt.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
I CANNOT get past step six. No matter how hard I pry, the pieces are not coming apart. I have pressed and twisted my screwdriver so much that it is damaging the plastic around it yet the pieces still stay together. What do I do?
Spencer Fantastic - Yanıt
Gotta buy the available 360 opener tool, its dirt cheap on aliexpress. Attempting via a screwdriver will just trash your case and get you nowhere.
Bootleg Joe (Snapman) -
When I get to step 11, there is literally no opening to be able to spin the wheel manually to open it and replace the band. Step 12 shows 2 rectangular openings in the front of the DVD drive, mine is solid plastic with no open gaps. There must be different types of drives used. Right now I cannot get to the belt to replace it. Anyone see this other type of drive? Any thoughts?
Joe Heeney - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 99
Son 30 gün: 495
Her zaman: 11,018
