Ana içeriğe geç
How to Replace the battery in a Timex Expedition Wristwatch
Neye ihtiyacın var
  1. How to Replace the battery in a Timex Expedition Wristwatch, Remove the back: adım 1, 1 resimden 1.
    • Removing the back requires a very thin jewelers screwdriver. I found one in an eyeglass repair kit that worked. Look for a place on the edge of the back plate where it is very slightly raised. Insert the screwdriver tip and pry upwards. It may not pop off all at once, it might take several incremental nudges before it releases.
  2. How to Replace the battery in a Timex Expedition Wristwatch, Replace the battery: adım 2, 1 resimden 1.
    • With the back off, I found that the battery is held in place at the bottom by a "T" shaped bracket secured by a very tiny screw. Delicately removing the screw, the bracket came off and I replaced the battery (CR2016). Then using my fingernails I dropped the tiny screw back in place and secured the bracket.
  3. How to Replace the battery in a Timex Expedition Wristwatch, Align the back plate: adım 3, 1 resimden 1.
    • Unfortunately, when I tested the alarm, it didn't work. The solution, it turns out, is that the back of the watch must be in a particular orientation. The correct orientation of the back plate is shown here.
    • You can test it by just holding the back plate in place with the fingers of one hand, and with the other hand pull out the alarm button. It should beep. If it doesn't beep, try adjusting the position of the back plate and try to hold it securely.
  4. How to Replace the battery in a Timex Expedition Wristwatch, Reassemble the back plate: adım 4, 3 resimden 1. How to Replace the battery in a Timex Expedition Wristwatch, Reassemble the back plate: adım 4, 3 resimden 2. How to Replace the battery in a Timex Expedition Wristwatch, Reassemble the back plate: adım 4, 3 resimden 3.
    • Once you have the back plate in the proper orientation it needs to be pressed into place. I found it impossible to perform this by hand. Eventually I found a short length of 3/4" PVC pipe.
    • Align the pipe with the back plate.
    • Place the watch and pipe in a vise. (Soft cloth used to protect the watch face). Slowly tighten the vise and you'll hear a pop when the back plate snaps into place.
Sonuç
With the watch reassembled, verify that it is functioning to your satisfaction.
10 farklı kişi bu kılavuzu tamamladı.
John Dalbey
614 İtibar
2 adet Kılavuz yazıldı
3Kılavuz Yorumları
Mine was a little different. Instead of a small T shaped bracket, my watch had one all the way across. One side hooked on a small hinge. The other had the tiny screw. Other than that small detail, your instructions were spot on.
Dave Lowe - Yanıt
I had no need for the PVC pipe, I was able to pop my watch face back in by hand.
It is useful for applying equal pressure and ensuring the watch remains waterproof
Darius - Yanıt
Excellent guide, I was able to replace the battery in 20 mins. I didn’t use the PVC pipe but a flat end of my 5 lb dumb bell, there rubber on the dumb bell so the back plate is not scratched.
Jin Wang - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 21
Son 7 gün: 189
Son 30 gün: 935
Her zaman: 37,336
