Ana içeriğe geç
How to Repot an Overgrown Monstera
Neye ihtiyacın var
  1. How to Repot an Overgrown Monstera, How to Repot an Overgrown Monstera: adım 1, 3 resimden 1. How to Repot an Overgrown Monstera, How to Repot an Overgrown Monstera: adım 1, 3 resimden 2. How to Repot an Overgrown Monstera, How to Repot an Overgrown Monstera: adım 1, 3 resimden 3.
    • Prepare the new pot by filling it around a third full with fresh potting soil.
    • Place the support stake in the desired location so the stake hits the bottom of the pot.
  2. How to Repot an Overgrown Monstera: adım 2, 1 resimden 1.
    • Tip the Monstera slowly onto its side and lift the roots sideways out of the old pot.
    • Support the roots and branches when transferring, and ensure not to break them.
  3. How to Repot an Overgrown Monstera: adım 3, 1 resimden 1.
    • Loosen and remove old soil from the root ball by gently massaging it away from the roots with your fingers.
  4. How to Repot an Overgrown Monstera: adım 4, 2 resimden 1. How to Repot an Overgrown Monstera: adım 4, 2 resimden 2.
    • Place the root ball in the new pot and place fresh soil around the root ball.
    • Leave an inch or two of space between the soil and the top of the pot.
  5. How to Repot an Overgrown Monstera: adım 5, 1 resimden 1.
    • Adjust the roots and leaves around the stake.
    • Direct any long aerial roots back toward the soil as you adjust the plant in the soil.
  6. How to Repot an Overgrown Monstera: adım 6, 1 resimden 1.
    • Tie the stems of the monstera up and down the stake to obtain even support and keep it upright.
    • Be careful not to break any leaves or stems by tying the plant to the stake too tightly.
  7. How to Repot an Overgrown Monstera: adım 7, 1 resimden 1.
    • Water the monstera well; the plant is properly saturated when water runs out of the holes in the bottom of the pot.
    • Water the plant over a trash bag or something that will catch the excess water.
Sonuç
In all, this is an easy at-home fix to keep a monstera plant healthy. This fix guides the user to remove and re-plant the monstera, and to water it at the end. We advise continued plant care and watering after repotting.
Owen Chen
145 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 1-7, Vidal-Chiesa Fall 2024 UC Davis, Team 1-7, Vidal-Chiesa Fall 2024 üyesi
UCD-VIDAL-CHIESA-F24S1G7
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 144
