Ana içeriğe geç
How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable
Neye ihtiyacın var
  1. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable, How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: adım 1, 2 resimden 1. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable, How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: adım 1, 2 resimden 2.
    • Carefully remove the plastic cover and set aside.
  2. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: adım 2, 3 resimden 1. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: adım 2, 3 resimden 2. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: adım 2, 3 resimden 3.
    • Remove the pad if there is one.
    • Spin the turntable until the belt and drive motor can be seen through a hole.
    • Gently pull the belt off of the motor, and make sure that the belt doesn’t bend or flip over.
    • Take off the turntable platter and set aside.
  3. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: adım 3, 3 resimden 1. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: adım 3, 3 resimden 2. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: adım 3, 3 resimden 3.
    • Remove the single screw from the middle white gear with a Phillips #00 screwdriver.
    • Have a cup or bin so you don’t lose the screw!
    • Gently pull the gear out, revealing the automatic mechanism.
  4. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: adım 4, 3 resimden 1. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: adım 4, 3 resimden 2. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: adım 4, 3 resimden 3.
    • Push the metal part away from the center. It should click into place.
    • Push the small metal part back to the center, towards the gear axle.
    • Push the metal part inward, close to the gear’s mounting point.
  5. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: adım 5, 1 resimden 1.
    • Replace the gear, making sure that the the metal latch on the gear is pushed back.
    • The central shaft should spin freely without hooking the gear.
    • Don't forget to put the band back on the drive motor when reassembling.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 77
Her zaman: 2,310
