Ana içeriğe geç
How to Resize Baggy Overalls
Neye ihtiyacın var
  1. How to Resize Baggy Overalls, How to Resize Baggy Overalls: adım 1, 3 resimden 1. How to Resize Baggy Overalls, How to Resize Baggy Overalls: adım 1, 3 resimden 2. How to Resize Baggy Overalls, How to Resize Baggy Overalls: adım 1, 3 resimden 3.
    • Try on the overalls.
    • Take your ruler and measure from the bottom of the crotch up to the desired crotch point.
    • Take note of your measurements.
  2. How to Resize Baggy Overalls: adım 2, 3 resimden 1. How to Resize Baggy Overalls: adım 2, 3 resimden 2. How to Resize Baggy Overalls: adım 2, 3 resimden 3.
    • Flip the overalls inside out and lay them flat.
    • Use the ruler to place the recorded intake length measured in Step 1.
    • Mark the top of this measurement on the center seam of the overalls.
  3. How to Resize Baggy Overalls: adım 3, 3 resimden 1. How to Resize Baggy Overalls: adım 3, 3 resimden 2. How to Resize Baggy Overalls: adım 3, 3 resimden 3.
    • Using your fabric chalk, draw an angled line from the top of your crotch point to blend seamlessly with the bottom of your inseam.
    • Measure the line just marked.
    • Repeat measurements on the other side.
  4. How to Resize Baggy Overalls: adım 4, 3 resimden 1. How to Resize Baggy Overalls: adım 4, 3 resimden 2. How to Resize Baggy Overalls: adım 4, 3 resimden 3.
    • Take your pins and pin them downwards along both lines.
    • Make sure to pin on both sides of the fabric and leave about 3" of spacing between each pin.
    • Be careful not to prod your fingers when pinning the fabric.
  5. How to Resize Baggy Overalls: adım 5, 2 resimden 1. How to Resize Baggy Overalls: adım 5, 2 resimden 2.
    • Try on the pinned overalls to ensure a comfortable fit.
    • If the measurements still need adjustment, head to Step 6.
    • If the measurements are perfect, head to Step 7.
    • Be careful when trying on the overalls. Wear a pair of long pants under to protect from being poked.
  6. How to Resize Baggy Overalls: adım 6, 3 resimden 1. How to Resize Baggy Overalls: adım 6, 3 resimden 2. How to Resize Baggy Overalls: adım 6, 3 resimden 3.
    • Lay your overalls back on a flat surface.
    • Take your fabric chalk and redraw your new measurements
    • Re-pin your new measurements.
  7. How to Resize Baggy Overalls: adım 7, 3 resimden 1. How to Resize Baggy Overalls: adım 7, 3 resimden 2. How to Resize Baggy Overalls: adım 7, 3 resimden 3.
    • Sewing machine set up will vary with each machine. Refer to the article in the introduction on How to Use a Sewing Machine as needed.
    • Bring your overalls under the sewing needle and line the needle to the top of the crotch marker.
    • Gently press the foot pedal below to slowly start moving your fabric along your chalk line.
    • When you reach a pin, pause machine before removing.
    • Run the machine through the end of your marker point.
    • Cut the excess thread after the pass.
  8. How to Resize Baggy Overalls: adım 8, 3 resimden 1. How to Resize Baggy Overalls: adım 8, 3 resimden 2. How to Resize Baggy Overalls: adım 8, 3 resimden 3.
    • Cut the fabric along the sewn seam.
    • Leave half an inch of fabric from your seam to prevent loosening.
  9. How to Resize Baggy Overalls: adım 9, 3 resimden 1. How to Resize Baggy Overalls: adım 9, 3 resimden 2. How to Resize Baggy Overalls: adım 9, 3 resimden 3.
    • Flip your overalls inside out.
    • Try them on and you're done!
Sonuç
Emily Le
169 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 2-1, Andersen Winter 2024 UC Davis, Team 2-1, Andersen Winter 2024 üyesi
UCD-ANDERSEN-W24S2G1
3 Üyeler
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 35
Son 30 gün: 132
Her zaman: 1,656
