Ana içeriğe geç
How to Restore Dried Clay
Neye ihtiyacın var
  1. How to Restore Dried Clay, How to Restore Dried Clay: adım 1, 1 resimden 1.
    • Break apart the dried clay into small pieces using a hard sturdy object, such as a mallet or a dull metal knife.
    • Smaller pieces will help the clay soften quicker.
  2. How to Restore Dried Clay: adım 2, 1 resimden 1.
    • Pour water into a container large enough for the clay you are restoring.
  3. How to Restore Dried Clay: adım 3, 1 resimden 1.
    • Add the broken clay to water.
    • Make sure the clay is completely covered in the water. This will help keep the clay texture smooth.
  4. How to Restore Dried Clay: adım 4, 1 resimden 1.
    • Soak the clay in water overnight for 24 hours.
    • The clay will become very soft and mushy.
  5. How to Restore Dried Clay: adım 5, 2 resimden 1. How to Restore Dried Clay: adım 5, 2 resimden 2.
    • Put on gloves to keep your hands clean.
  6. How to Restore Dried Clay: adım 6, 1 resimden 1.
    • Place a plastic bag or plastic wrap on your working surface.
    • This helps keep your working surface and your clay clean.
  7. How to Restore Dried Clay: adım 7, 1 resimden 1.
    • Scoop out the softened clay from your container and place it on the plastic.
    • Use both hands to scoop the clay, then scrape it off your hands and onto the plastic sheet.
  8. How to Restore Dried Clay: adım 8, 1 resimden 1.
    • Use your hand to flatten and spread the clay out on the plastic.
    • Use both hands to scrape off any clay that sticks to your gloves.
  9. How to Restore Dried Clay: adım 9, 1 resimden 1.
    • Let your clay sit for a day until it is soft to the touch and no longer sticking to your fingers.
    • The thinner/more spread out the clay, the faster it will dry.
    • Check on clay every few hours to make sure it doesn't dry out completely.
  10. How to Restore Dried Clay: adım 10, 1 resimden 1.
    • Knead the clay by massaging it with your hands. Continue until the clay is combined.
    • You can also push and press the clay against your working surface to combine it.
  11. How to Restore Dried Clay: adım 11, 3 resimden 1. How to Restore Dried Clay: adım 11, 3 resimden 2. How to Restore Dried Clay: adım 11, 3 resimden 3.
    • Tightly wrap your clay in plastic wrap to make sure it doesn't dry up again.
    • Avoid air bubbles by pressing the plastic wrap against the surface of the clay.
Sonuç
Keep your clay tightly wrapped up or placed within an air tight container to keep it from drying out again. Adding water onto the clay also helps to keep it soft and manageable.
2 farklı kişi bu kılavuzu tamamladı.
Moss
223 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 4-7, Whithaus Spring 2024 UC Davis, Team 4-7, Whithaus Spring 2024 üyesi
UCD-WHITHAUS-S24S4G7
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 35
Her zaman: 363
