Giriş
In the event that a note in your harmonica has become unplayable, it's very likely that the reed has become misaligned and needs to be restored to its proper position.
Within this guide, you will be able to take apart your harmonica, clean the reeds, and finally warp the troubled reed back in place.
In addition to the listed tools, certain items will also be required such as a bowl to hold water and vinegar, a small soft brush, and a flat implement such as a knife.
Neye ihtiyacın var
Remove the 8mm Phillips #1 screws on each end of the Harmonica holding the cover plates in place and set these aside.
Set aside both the top and bottom cover plates
Bir başkası bu kılavuzu tamamladı.
