Ana içeriğe geç
How to Restore Wool’s Water Resistance
Neye ihtiyacın var
  1. How to Restore Wool’s Water Resistance, How to Restore Wool’s Water Resistance: adım 1, 3 resimden 1. How to Restore Wool’s Water Resistance, How to Restore Wool’s Water Resistance: adım 1, 3 resimden 2. How to Restore Wool’s Water Resistance, How to Restore Wool’s Water Resistance: adım 1, 3 resimden 3.
    • Fill a bowl with water at room temperature (20 °C or 68 °F).
    • Use 2 L of water per 200 g of wool.
  2. How to Restore Wool’s Water Resistance: adım 2, 1 resimden 1.
    • Add 1/2 teaspoon of wool wash per 2 L of water.
  3. How to Restore Wool’s Water Resistance: adım 3, 2 resimden 1. How to Restore Wool’s Water Resistance: adım 3, 2 resimden 2.
    • Insert the articles into the bowl and let soak for 30 minutes.
    • Carefully squeeze the items to allow absorption of soap and water through the wool fibres.
  4. How to Restore Wool’s Water Resistance: adım 4, 1 resimden 1.
    • Lift the items out of the water and gently squeeze to remove excess water and soap.
  5. How to Restore Wool’s Water Resistance: adım 5, 1 resimden 1.
    • Refill the bowl with room temperature water.
    • Use the same volume of water as in Step 1.
  6. How to Restore Wool’s Water Resistance: adım 6, 2 resimden 1. How to Restore Wool’s Water Resistance: adım 6, 2 resimden 2.
    • Mix 4 tablespoons of emulsified lanolin into 2 liters of water.
  7. How to Restore Wool’s Water Resistance: adım 7, 2 resimden 1. How to Restore Wool’s Water Resistance: adım 7, 2 resimden 2.
    • Add the articles and squeeze to saturate.
    • Weight the articles with a heavy glass or a dish.
    • Leave to soak for 30 minutes.
  8. How to Restore Wool’s Water Resistance: adım 8, 2 resimden 1. How to Restore Wool’s Water Resistance: adım 8, 2 resimden 2.
    • Pull the articles out of the lanolin bath and gently squeeze out excess water.
  9. How to Restore Wool’s Water Resistance: adım 9, 1 resimden 1.
    • Lay flat to dry with a clean towel beneath the items.
    • Do not line dry. It can cause wool to stretch and lose shape.
    • Avoid direct sunlight or direct heat when drying.
Bitiş Çizgisi
Yuliya S
169 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 40
Her zaman: 767
