Ana içeriğe geç
How to Restore a Torn Nike Flip-Flop
Neye ihtiyacın var
  1. How to Restore a Torn Nike Flip-Flop, How to Restore a Torn Nike Flip-Flop: adım 1, 1 resimden 1.
    • Remove all rough edges with 120 grit sandpaper from the torn parts of the flip-flop.
  2. How to Restore a Torn Nike Flip-Flop: adım 2, 2 resimden 1. How to Restore a Torn Nike Flip-Flop: adım 2, 2 resimden 2.
    • Clean off any additional residue with soap, water, and a towel or toothbrush.
    • Allow the flip-flop to air dry before moving on.
  3. How to Restore a Torn Nike Flip-Flop: adım 3, 1 resimden 1.
    • Gently apply the adhesive on the torn parts of the flip-flop.
    • Make sure the torn parts are completely covered. Overspill is okay.
    • Connect and hold the parts of the flip-flop to the adhesive with your hands for 5 minutes. After the 5 minutes the adhesive will be hard enough to let it sit. Let the adhesive dry for 24 hours.
    • Be sure to wear gloves and be in a ventilated environment when applying the adhesive.
  4. How to Restore a Torn Nike Flip-Flop: adım 4, 1 resimden 1.
    • Once the adhesive is dry remove any extra adhesive that might have spilled over with the sandpaper.
  5. How to Restore a Torn Nike Flip-Flop: adım 5, 3 resimden 1. How to Restore a Torn Nike Flip-Flop: adım 5, 3 resimden 2. How to Restore a Torn Nike Flip-Flop: adım 5, 3 resimden 3.
    • Take the needle and thread and begin to sew a cross stitch from the strap to the torn part of the flip-flop.
    • It may be easier to use an upholstery needle to get through the rubber material.
  6. How to Restore a Torn Nike Flip-Flop: adım 6, 1 resimden 1.
    • Cover the stitched region with Plasti Dip.
    • Allow 4 hours to dry.
    • Make sure to apply the Plastic Dip in a proper environment with venalation or outside.
Sonuç
The Nike Flip-Flop(s) are now restored and can be worn again.
7 farklı kişi bu kılavuzu tamamladı.
Adrian Yearby
265 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team S1-G2, Rauch Summer 2017 Texas Tech, Team S1-G2, Rauch Summer 2017 üyesi
TTU-RAUCH-SU17S1G2
2 Üyeler
2 adet Kılavuz yazıldı
2Kılavuz Yorumları
Hi Andrew! Thank you so much for this example. What kind of adhesive did you use, because there are so many versions. Thank you.
masood daud - Yanıt
Oh darn I see it now.lol
masood daud - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 24
Son 30 gün: 80
Her zaman: 19,322
