Ana içeriğe geç
How to Restring a French Horn
Neye ihtiyacın var
  1. How to Restring a French Horn, How to Restring a French Horn: adım 1, 3 resimden 1. How to Restring a French Horn, How to Restring a French Horn: adım 1, 3 resimden 2. How to Restring a French Horn, How to Restring a French Horn: adım 1, 3 resimden 3.
    • Place your horn where the back is easily accessible.
    • Loosen the set of screws, but DON’T take them out! Just loosen them enough that the string can wrap around.
  2. How to Restring a French Horn: adım 2, 3 resimden 1. How to Restring a French Horn: adım 2, 3 resimden 2. How to Restring a French Horn: adım 2, 3 resimden 3.
    • Cut about 7-8 inches of string only if you are going to use a brand new roll of string, and tie a small knot on one end of the string.
    • If it is the exact string, make sure there is a knot at the one end of the string.
    • With the knot, the string should be about 51/2-6 inches.
  3. How to Restring a French Horn: adım 3, 2 resimden 1. How to Restring a French Horn: adım 3, 2 resimden 2.
    • Put the string in the top hole of the valve and pull.
    • You are going to pull it toward the bottom and wrap it at the bottom of the rotor post.
  4. How to Restring a French Horn: adım 4, 3 resimden 1. How to Restring a French Horn: adım 4, 3 resimden 2. How to Restring a French Horn: adım 4, 3 resimden 3.
    • Wrap the string around the screw and tighten the screw.
  5. How to Restring a French Horn: adım 5, 3 resimden 1. How to Restring a French Horn: adım 5, 3 resimden 2. How to Restring a French Horn: adım 5, 3 resimden 3.
    • Pull the string to wrap the top of the rotor.
    • Put the string into the hole at the bottom of the valve.
  6. How to Restring a French Horn: adım 6, 3 resimden 1. How to Restring a French Horn: adım 6, 3 resimden 2. How to Restring a French Horn: adım 6, 3 resimden 3.
    • Wrap the string around the screw.
    • Tighten the screw.
  7. How to Restring a French Horn: adım 7, 3 resimden 1. How to Restring a French Horn: adım 7, 3 resimden 2. How to Restring a French Horn: adım 7, 3 resimden 3.
    • Make sure your valve buttons are leveled, if it is too tight or to loose where it is not leveled, then you will have to repeat steps 1-6.
    • If your horn looks like any of these photos then congrats!! You are finished.
    • You may now move on with your day and go practice! Make sure to press the valve a coupe of times to make sure everything is secure well.
Sonuç
Claudia aguilar
145 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 189
