Ana içeriğe geç
How to Restring a Women's Lacrosse Head
Neye ihtiyacın var
  1. How to Restring a Women's Lacrosse Head, How to Restring a Women's Lacrosse Head: adım 1, 3 resimden 1. How to Restring a Women's Lacrosse Head, How to Restring a Women's Lacrosse Head: adım 1, 3 resimden 2. How to Restring a Women's Lacrosse Head, How to Restring a Women's Lacrosse Head: adım 1, 3 resimden 3.
    • Prep the nylon strings for the pocket with a poachers knot.
    • Create this knot at one end of each nylon.
    • There are two nylons for this stringing instruction.
  2. How to Restring a Women's Lacrosse Head: adım 2, 2 resimden 1. How to Restring a Women's Lacrosse Head: adım 2, 2 resimden 2.
    • Tie a double knot on a sidewall string.
    • Make sure the lacrosse head is face down.
  3. How to Restring a Women's Lacrosse Head: adım 3, 3 resimden 1. How to Restring a Women's Lacrosse Head: adım 3, 3 resimden 2. How to Restring a Women's Lacrosse Head: adım 3, 3 resimden 3.
    • Lace the string through the topmost sidewall hole.
    • Skip a hole.
  4. How to Restring a Women's Lacrosse Head: adım 4, 3 resimden 1. How to Restring a Women's Lacrosse Head: adım 4, 3 resimden 2. How to Restring a Women's Lacrosse Head: adım 4, 3 resimden 3.
    • Thread the end of the sidewall-string through the loop made via "stitch."
    • Pull tight, towards the next hole.
  5. How to Restring a Women's Lacrosse Head: adım 5, 1 resimden 1.
    • Repeat step 3 all the way down the side wall, skipping a hole each time.
    • Tie off at the end. Repeat for the other sidewall.
    • Ensure that the holes match up on both sides.
    • Stitches should be facing inwards.
  6. How to Restring a Women's Lacrosse Head: adım 6, 2 resimden 1. How to Restring a Women's Lacrosse Head: adım 6, 2 resimden 2.
    • Knot the top-string on one end.
    • Thread the top-string through the topmost sidewall hole with the sidewall-string knot.
  7. How to Restring a Women's Lacrosse Head: adım 7, 3 resimden 1. How to Restring a Women's Lacrosse Head: adım 7, 3 resimden 2. How to Restring a Women's Lacrosse Head: adım 7, 3 resimden 3.
    • Start each hole with pulling the string back to front.
    • Pull tight!
    • Feed the top-string through the 1st leather.
  8. How to Restring a Women's Lacrosse Head: adım 8, 3 resimden 1. How to Restring a Women's Lacrosse Head: adım 8, 3 resimden 2. How to Restring a Women's Lacrosse Head: adım 8, 3 resimden 3.
    • Thread the top-string front to back.
    • Pull tight!
    • Make sure that the continuing string comes in front of the knot.
    • Start the same loop pattern on the next hole. (back to front)
  9. How to Restring a Women's Lacrosse Head: adım 9, 3 resimden 1. How to Restring a Women's Lacrosse Head: adım 9, 3 resimden 2. How to Restring a Women's Lacrosse Head: adım 9, 3 resimden 3.
    • Grab one of the prepped nylons from step 1.
    • Thread the top-string through the nylon poacher's knot.
    • Finish the loop pattern by pulling tight. (front to back)
  10. How to Restring a Women's Lacrosse Head: adım 10, 2 resimden 1. How to Restring a Women's Lacrosse Head: adım 10, 2 resimden 2.
    • Repeat Step 9 to tie in the second nylon.
    • Repeat Step 8 to tie in the second leather.
    • Pull through the top sidewall.
    • Tie off with a knot.
  11. How to Restring a Women's Lacrosse Head: adım 11, 3 resimden 1. How to Restring a Women's Lacrosse Head: adım 11, 3 resimden 2. How to Restring a Women's Lacrosse Head: adım 11, 3 resimden 3.
    • Lace all the 4 strings through their respective holes at the bottom of head.
    • Do not tie off yet!
    • Push the leathers and the nylons to the desired pocket depth.
  12. How to Restring a Women's Lacrosse Head: adım 12, 2 resimden 1. How to Restring a Women's Lacrosse Head: adım 12, 2 resimden 2.
    • Thread the pocket cross-string through both nylon strings.
    • For this manual, the pocket will be black.
    • Ensure that once pulled, both end lengths are the same.
  13. How to Restring a Women's Lacrosse Head: adım 13, 3 resimden 1. How to Restring a Women's Lacrosse Head: adım 13, 3 resimden 2. How to Restring a Women's Lacrosse Head: adım 13, 3 resimden 3.
    • Wrap the cross-string up and around its adjacent nylon.
    • Bring both of the string ends towards center to form a twist.
    • Finish by wrapping the string around each nylon again.
  14. How to Restring a Women's Lacrosse Head: adım 14, 2 resimden 1. How to Restring a Women's Lacrosse Head: adım 14, 2 resimden 2.
    • Repeat the twists and wraps in Step 13 until the end of the nylons.
    • Pull the ends of black cross-strings through the same holes the nylon strings are tied off at.
    • The pocket should consist of 8-10 twists. (The pocket tightness is based on the player's preference.)
  15. How to Restring a Women's Lacrosse Head: adım 15, 3 resimden 1. How to Restring a Women's Lacrosse Head: adım 15, 3 resimden 2. How to Restring a Women's Lacrosse Head: adım 15, 3 resimden 3.
    • Thread the cross-string through the top of the leather.
    • The inner cross string will be blue for this manual.
    • Make sure that each end of the cross-string is of even length.
    • Bring the cross-string under the nylon and through the first twist of the black pocket string.
    • Lock the string in place by bringing it back around itself and pulling down.
  16. How to Restring a Women's Lacrosse Head: adım 16, 3 resimden 1. How to Restring a Women's Lacrosse Head: adım 16, 3 resimden 2. How to Restring a Women's Lacrosse Head: adım 16, 3 resimden 3.
    • Wrap the cross-string around the leather, front to back.
    • Thread the cross-string under nylon and through the second twist of the black cross-string.
    • Repeat this pattern (steps 15-16) until each twist in the pocket has been threaded through.
    • Pull the end of the cross-string through the hole of the leather at the bottom.
  17. How to Restring a Women's Lacrosse Head: adım 17, 3 resimden 1. How to Restring a Women's Lacrosse Head: adım 17, 3 resimden 2. How to Restring a Women's Lacrosse Head: adım 17, 3 resimden 3.
    • Thread the remining blue cross-string through the first loop of the sidewall string.
    • This will create the outer cross-string section.
    • Wrap the cross-string around the leather.
    • Twist the cross-string around itself so it's "locked."
    • Repeat this step, threading through each sidewall loop until the bottom.
  18. How to Restring a Women's Lacrosse Head: adım 18, 2 resimden 1. How to Restring a Women's Lacrosse Head: adım 18, 2 resimden 2.
    • Repeat steps 15-17 to string the other side. (inner and outer cross-string)
    • Thread both of the ends of the blue cross-string through the same hole the leathers go through.
    • Knot the two ends together to tie off.
    • Repeat for the other blue cross-string ends.
  19. How to Restring a Women's Lacrosse Head: adım 19, 2 resimden 1. How to Restring a Women's Lacrosse Head: adım 19, 2 resimden 2.
    • Thread the first shooting lace through the second hole down on the left side of the head.
  20. How to Restring a Women's Lacrosse Head: adım 20, 3 resimden 1. How to Restring a Women's Lacrosse Head: adım 20, 3 resimden 2. How to Restring a Women's Lacrosse Head: adım 20, 3 resimden 3.
    • Weave over the blue cross-string.
    • Weave under the leather.
    • Weave over the nylon.
    • Weave under the black pocket-twist.
  21. How to Restring a Women's Lacrosse Head: adım 21, 3 resimden 1. How to Restring a Women's Lacrosse Head: adım 21, 3 resimden 2. How to Restring a Women's Lacrosse Head: adım 21, 3 resimden 3.
    • Thread the lace's end through the second sidewall hole down.
    • Return the shooter-lace over the sidewall hole.
    • Create an opposite weave of over and under through each section.
    • Be sure to twist the lace around itself as you weave over and under.
  22. How to Restring a Women's Lacrosse Head: adım 22, 2 resimden 1. How to Restring a Women's Lacrosse Head: adım 22, 2 resimden 2.
    • Tie off the shooter lace with itself, creating a knot over the sidewall hole.
  23. How to Restring a Women's Lacrosse Head: adım 23, 2 resimden 1. How to Restring a Women's Lacrosse Head: adım 23, 2 resimden 2.
    • Cut off any excess lace, leaving about an inch.
    • Make sure to cut after the knot.
  24. How to Restring a Women's Lacrosse Head: adım 24, 3 resimden 1. How to Restring a Women's Lacrosse Head: adım 24, 3 resimden 2. How to Restring a Women's Lacrosse Head: adım 24, 3 resimden 3.
    • Pull the 2nd shooter lace through the 5th or 6th sidewall hole from the bottom.
    • The position will be based on player preference.
  25. How to Restring a Women's Lacrosse Head: adım 25, 3 resimden 1. How to Restring a Women's Lacrosse Head: adım 25, 3 resimden 2. How to Restring a Women's Lacrosse Head: adım 25, 3 resimden 3.
    • Weave the shooter lace under the cross-string.
    • Weave over the leather.
    • Weave under the next cross lace.
    • Weave under the center pocket strings.
    • Create an upside-down U shape to help form a defined pocket.
    • Pull the lace through the sidewall hole across from the starting point (5th or 6th up from bottom).
  26. How to Restring a Women's Lacrosse Head: adım 26, 3 resimden 1. How to Restring a Women's Lacrosse Head: adım 26, 3 resimden 2. How to Restring a Women's Lacrosse Head: adım 26, 3 resimden 3.
    • Thread the shooter-lace back through the U-shape, inversing the over/under pattern.
    • Be sure to twist the lace around itself as done with the first shooter lace in steps 22-23.
  27. How to Restring a Women's Lacrosse Head: adım 27, 1 resimden 1.
    • Tie off the shooting lace using both ends.
  28. How to Restring a Women's Lacrosse Head: adım 28, 3 resimden 1. How to Restring a Women's Lacrosse Head: adım 28, 3 resimden 2. How to Restring a Women's Lacrosse Head: adım 28, 3 resimden 3.
    • Cut the excess off of all strings that are tied off with knots.
    • Leave 1/2 an inch or so on each string for tightening purposes.
  29. How to Restring a Women's Lacrosse Head: adım 29, 2 resimden 1. How to Restring a Women's Lacrosse Head: adım 29, 2 resimden 2.
    • Use a glue gun to seal all of the cut strings.
    • Glue gun tip and fresh glue is very hot!
  30. How to Restring a Women's Lacrosse Head: adım 30, 2 resimden 1. How to Restring a Women's Lacrosse Head: adım 30, 2 resimden 2.
    • Use a lacrosse ball to test the depth and tension of your completed pocket.
    • Readjust as needed.
Sonuç
This guide is a complete replacement of all strings. Each step per string can be done solo if only one string-part of the lacrosse head needs repair.
Bir başkası bu kılavuzu tamamladı.
Katharine Strong
425 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 2-1, Vidal-Chiesa Fall 2024 UC Davis, Team 2-1, Vidal-Chiesa Fall 2024 üyesi
UCD-VIDAL-CHIESA-F24S2G1
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 66
