Ana içeriğe geç
How to Reupholster a Bench Cushion
Neye ihtiyacın var
  1. How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: adım 1, 3 resimden 1. How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: adım 1, 3 resimden 2. How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: adım 1, 3 resimden 3.
    • Remove the base from the frame of the bench.
    • If the base is screwed on the frame, use a screwdriver or a drill to remove the screws.
  2. How to Reupholster a Bench Cushion: adım 2, 3 resimden 1. How to Reupholster a Bench Cushion: adım 2, 3 resimden 2. How to Reupholster a Bench Cushion: adım 2, 3 resimden 3.
    • Lift the staples with the flathead screwdriver before going in with the pliers.
  3. How to Reupholster a Bench Cushion: adım 3, 3 resimden 1. How to Reupholster a Bench Cushion: adım 3, 3 resimden 2. How to Reupholster a Bench Cushion: adım 3, 3 resimden 3.
    • Use a pair of pliers to grip the staples.
    • Twist and pull the staples to remove them from the bench.
  4. How to Reupholster a Bench Cushion: adım 4, 3 resimden 1. How to Reupholster a Bench Cushion: adım 4, 3 resimden 2. How to Reupholster a Bench Cushion: adım 4, 3 resimden 3.
    • Place clean material down so the new fabric does not get dirty.
    • Place the fabric with the design face down on top of the clean sheet.
    • Then place the cushion, then the base face down.
  5. How to Reupholster a Bench Cushion: adım 5, 3 resimden 1. How to Reupholster a Bench Cushion: adım 5, 3 resimden 2. How to Reupholster a Bench Cushion: adım 5, 3 resimden 3.
    • Keep the safety lock closed when not using the staple gun.
    • When ready to use the staple gun, pull the safety lock down.
    • Insert the staples into the stapler.
  6. How to Reupholster a Bench Cushion: adım 6, 3 resimden 1. How to Reupholster a Bench Cushion: adım 6, 3 resimden 2. How to Reupholster a Bench Cushion: adım 6, 3 resimden 3.
    • Pull the fabric taut and staple every 4 inches.
  7. How to Reupholster a Bench Cushion: adım 7, 3 resimden 1. How to Reupholster a Bench Cushion: adım 7, 3 resimden 2. How to Reupholster a Bench Cushion: adım 7, 3 resimden 3.
    • Fold the corners of the fabric inward then on top.
    • Staple the fabric down twice for each corner.
    • Cut the excess fabric along the shorter sides of the base length.
    • Place the base back onto the frame.
    • If any screws were removed, screw them back on.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Xochitl Vara
169 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 450
