Giriş
Have you ever thrown out nail polish because it has dried out? Many people don't know that dry nail polish can actually be saved. In a couple simple steps you can reuse dry nail polish without the need of buying new bottles.
Neye ihtiyacın var
Find a clean workplace where you can easily clean up spills.
You can use a few drops of 91% isopropyl alcohol or ethyl acetate as solvents for thinning nail polish.
Open the bottle of dry nail polish setting the brush to the side.
Open the bottle of nail polish thinner.
Squirt 2 drops of nail polish thinner into the dry nail polish.
Screw the top back onto the dry nail polish and roll the bottle between your hands to mix. Shaking the bottle can put air bubbles in the nail polish and ruin a manicure.
Your steps are great! It might be faster to navigate everything if you put distinct actions separated as individual bullet points.
The following list shows what I mean by "distinct actions."
Screw the top back onto the nail polish.
Shake the nail polish bottle.
If the nail polish is still dry or thick repeat steps 2-3 until the nail polish is finally thinned.
Instead of using the ‘/‘ character, increase user-friendliness by using a conjunction like " thick and dry."
This is nit-picky, but "usable" means liquified? Thinned?
The added warning is awesome. Do you have any remedies in case the user does make the mistake of creating watery nail polish?
The nail polish should reach its regular consistency after applying the nail thinner. You may then be able to apply your nail polish onto your nails.
6 farklı kişi bu kılavuzu tamamladı.
Consider using bullet points to separate each individual action. (This is explained further in a comment for step 2).
Annamarie Roger - Yanıt
You only have one tool which increases simplicity!
However, you may want to include a rag and/or remind users to have a clean workspace before beginning this guide.
