Ana içeriğe geç
How to Safely Remove Stickers from a Hydro Flask
Neye ihtiyacın var
  1. How to Safely Remove Stickers from a Hydro Flask, How to Safely Remove Stickers from a Hydro Flask: adım 1, 1 resimden 1.
    • Soak the water bottle in warm water for 10 minutes.
  2. How to Safely Remove Stickers from a Hydro Flask: adım 2, 2 resimden 1. How to Safely Remove Stickers from a Hydro Flask: adım 2, 2 resimden 2.
    • Dry the water bottle with a towel.
  3. How to Safely Remove Stickers from a Hydro Flask: adım 3, 3 resimden 1. How to Safely Remove Stickers from a Hydro Flask: adım 3, 3 resimden 2. How to Safely Remove Stickers from a Hydro Flask: adım 3, 3 resimden 3.
    • Turn the hair dryer on high heat.
    • Apply heat to each sticker for 30 seconds.
    • Slowly peel the sticker off while applying heat.
    • Caution: Be careful not to burn your fingers when peeling off the sticker.
  4. How to Safely Remove Stickers from a Hydro Flask: adım 4, 3 resimden 1. How to Safely Remove Stickers from a Hydro Flask: adım 4, 3 resimden 2. How to Safely Remove Stickers from a Hydro Flask: adım 4, 3 resimden 3.
    • Lather the water bottle in warm soapy water.
    • Scrub away at the residue with a sponge.
    • Dry down the water bottle with a towel.
  5. How to Safely Remove Stickers from a Hydro Flask: adım 5, 3 resimden 1. How to Safely Remove Stickers from a Hydro Flask: adım 5, 3 resimden 2. How to Safely Remove Stickers from a Hydro Flask: adım 5, 3 resimden 3.
    • Pour the isopropyl alcohol onto a cotton pad so that it is fully soaked.
    • Using pressure, rub the residue off of the water bottle with the cotton pad.
  6. How to Safely Remove Stickers from a Hydro Flask: adım 6, 3 resimden 1. How to Safely Remove Stickers from a Hydro Flask: adım 6, 3 resimden 2. How to Safely Remove Stickers from a Hydro Flask: adım 6, 3 resimden 3.
    • Scrape off the residue with a card. Scrape up to down.
    • Scrape from right to left.
  7. How to Safely Remove Stickers from a Hydro Flask: adım 7, 3 resimden 1. How to Safely Remove Stickers from a Hydro Flask: adım 7, 3 resimden 2. How to Safely Remove Stickers from a Hydro Flask: adım 7, 3 resimden 3.
    • Coat a cotton swab in the isopropyl alcohol.
    • With pressure, rub off the residue with the cotton swab.
    • For any difficult residue follow this step.
  8. How to Safely Remove Stickers from a Hydro Flask: adım 8, 2 resimden 1. How to Safely Remove Stickers from a Hydro Flask: adım 8, 2 resimden 2.
    • Enjoy your new water bottle!
Bitiş Çizgisi
Karley Makar
157 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 4-5, Vidal-Chiesa Fall 2024 UC Davis, Team 4-5, Vidal-Chiesa Fall 2024 üyesi
UCD-VIDAL-CHIESA-F24S4G5
2 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 35
Her zaman: 308
