Ana içeriğe geç
How to Shorten a Sweatshirt Using the Original Hem
Neye ihtiyacın var
  1. How to Shorten a Sweatshirt Using the Original Hem, How to Shorten a Sweatshirt Using the Original Hem: adım 1, 1 resimden 1.
    • Lay your crewneck on a flat surface.
  2. How to Shorten a Sweatshirt Using the Original Hem: adım 2, 2 resimden 1. How to Shorten a Sweatshirt Using the Original Hem: adım 2, 2 resimden 2.
    • Find your new desired length and mark it with chalk.
    • Using your chalk mark, use a ruler to mark across the width of your crewneck.
  3. How to Shorten a Sweatshirt Using the Original Hem: adım 3, 1 resimden 1.
    • Measure one inch below your desired length and mark using chalk.
  4. How to Shorten a Sweatshirt Using the Original Hem: adım 4, 2 resimden 1. How to Shorten a Sweatshirt Using the Original Hem: adım 4, 2 resimden 2.
    • Cut along your newly marked line.
    • Make sure to cut one layer at a time to ensure a clean cut.
  5. How to Shorten a Sweatshirt Using the Original Hem: adım 5, 1 resimden 1.
    • Using a ruler, mark 1/2 an inch up from the hem of your crewneck.
  6. How to Shorten a Sweatshirt Using the Original Hem: adım 6, 1 resimden 1.
  7. How to Shorten a Sweatshirt Using the Original Hem: adım 7, 1 resimden 1.
    • Flip the hem inside out and align with the cut edge of your crewneck.
    • Make sure the pieces are "good side" to "good side" by ensuring the seams are facing outward.
  8. How to Shorten a Sweatshirt Using the Original Hem: adım 8, 1 resimden 1.
    • Pin both pieces together with all pins facing perpendicularly to the lines you marked.
  9. How to Shorten a Sweatshirt Using the Original Hem: adım 9, 2 resimden 1. How to Shorten a Sweatshirt Using the Original Hem: adım 9, 2 resimden 2.
    • Sew one inch away from the edge, removing the pins as you go.
    • This step can also be done by hand with thread and a needle.
  10. How to Shorten a Sweatshirt Using the Original Hem: adım 10, 2 resimden 1. How to Shorten a Sweatshirt Using the Original Hem: adım 10, 2 resimden 2.
    • Flip the hem right side out and admire your creation!
Bitiş Çizgisi
Izzy DeLaGarza
181 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 4-8, Vidal-Chiesa Fall 2024 UC Davis, Team 4-8, Vidal-Chiesa Fall 2024 üyesi
UCD-VIDAL-CHIESA-F24S4G8
3 Üyeler
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 46
Son 30 gün: 222
Her zaman: 1,156
