Ana içeriğe geç
How to Shrink a Tennis Racket Grip
Neye ihtiyacın var
  1. How to Shrink a Tennis Racket Grip, Remove Grip Tape: adım 1, 1 resimden 1.
    • Pull the tape until it comes off of the grip.
    • Use a sharp object to cut it off if needed.
  2. How to Shrink a Tennis Racket Grip, Remove the Overgrip: adım 2, 2 resimden 1. How to Shrink a Tennis Racket Grip, Remove the Overgrip: adım 2, 2 resimden 2.
    • If your racket does not have an overgrip on it, then skip this step.
    • There is a good chance it is sticky.
  3. How to Shrink a Tennis Racket Grip, Put the Overgrip at the Bottom of the Handle: adım 3, 1 resimden 1.
    • Attach the smaller end of the new overgrip to the bottom of the handle.
    • Wrap the overgrip around the handle, parallel to the bottom of the grip.
  4. How to Shrink a Tennis Racket Grip, Wrap the Overgrip around the Handle: adım 4, 1 resimden 1.
    • Pull the grip tightly, leaving little to no open areas between the different parts of the overgrip.
    • Leave a little overlap between each row of your grip.
    • Most of your overgrip should cover the handle instead of a lower row of overgrip.
    • Make each row as close to the same size as possible.
  5. How to Shrink a Tennis Racket Grip, Put on the Tape: adım 5, 2 resimden 1. How to Shrink a Tennis Racket Grip, Put on the Tape: adım 5, 2 resimden 2.
    • It should tie the end of the grip to the rest of the racket.
    • I did not cut the end of the overgrip with scissors. If you want the grip to fit better, cut the end of the overgrip off at a 45 degree angle.
Sonuç
If you decide that you want to go back to the racket grip's original size, then you need to remove the overgrip and put on a replacement grip.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 7
Son 30 gün: 9
Her zaman: 151
