Ana içeriğe geç
How to Stabilize the Stem of a Longwise ES06 E-Scooter
Neye ihtiyacın var
  1. How to Stabilize the Stem of a Longwise ES06 E-Scooter, How to Stabilize the Stem of a Longwise ES06 E-Scooter: adım 1, 2 resimden 1. How to Stabilize the Stem of a Longwise ES06 E-Scooter, How to Stabilize the Stem of a Longwise ES06 E-Scooter: adım 1, 2 resimden 2.
    • Power off your E-Scooter and make sure it is not charging.
  2. How to Stabilize the Stem of a Longwise ES06 E-Scooter: adım 2, 2 resimden 1. How to Stabilize the Stem of a Longwise ES06 E-Scooter: adım 2, 2 resimden 2.
    • Slide the locking clip out from the base of the stem.
    • Unlock the clamp on the stem.
  3. How to Stabilize the Stem of a Longwise ES06 E-Scooter: adım 3, 2 resimden 1. How to Stabilize the Stem of a Longwise ES06 E-Scooter: adım 3, 2 resimden 2.
    • Gently lower the stem onto the back wheel and keep it stable.
  4. How to Stabilize the Stem of a Longwise ES06 E-Scooter: adım 4, 3 resimden 1. How to Stabilize the Stem of a Longwise ES06 E-Scooter: adım 4, 3 resimden 2. How to Stabilize the Stem of a Longwise ES06 E-Scooter: adım 4, 3 resimden 3.
    • Using an adjustable wrench, carefully tighten the bolt at the base of the stem.
    • This will make the stem stable.
    • Do not use the wrench on the spring between the stem and the bolt as it may damage the wires beneath.
  5. How to Stabilize the Stem of a Longwise ES06 E-Scooter: adım 5, 3 resimden 1. How to Stabilize the Stem of a Longwise ES06 E-Scooter: adım 5, 3 resimden 2. How to Stabilize the Stem of a Longwise ES06 E-Scooter: adım 5, 3 resimden 3.
    • Using a slotted/flathead screwdriver, carefully tighten the screw on the clamp.
    • This will prevent the clamp from popping open.
  6. How to Stabilize the Stem of a Longwise ES06 E-Scooter: adım 6, 2 resimden 1. How to Stabilize the Stem of a Longwise ES06 E-Scooter: adım 6, 2 resimden 2.
    • Use a Phillips #0 to tighten the screw on the locking clip.
    • This helps the clamp to stay in place and prevent it from popping open.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Maithili Admane
145 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 38
Her zaman: 1,320
