Ana içeriğe geç
How to Start Up a Mac in Internet Recovery Mode
    1. How to Start Up a Mac in Internet Recovery Mode, How to Start Up a Mac in Internet Recovery Mode: adım 1, 1 resimden 1.
      • Shut down the computer.
      • If you're installing MacOS to a new drive with Internet Recovery, you can skip this step.
      FixBot'a Sor
      Yorum Ekle
    2. How to Start Up a Mac in Internet Recovery Mode: adım 2, 1 resimden 1.
      • Once the computer is completely shut down, press the power button, then immediately press and hold the key combination cmd + option + R.
      FixBot'a Sor
      Yorum Ekle
    3. How to Start Up a Mac in Internet Recovery Mode: adım 3, 2 resimden 1. How to Start Up a Mac in Internet Recovery Mode: adım 3, 2 resimden 2.
      • When the spinning globe animation appears, you can release the keys.
      • The globe will spin while Internet Recovery starts up. If you are not using a wired internet connection, a choose network prompt will appear. Use this menu to connect the computer to a WiFi network.
      FixBot'a Sor
      Yorum Ekle
    4. How to Start Up a Mac in Internet Recovery Mode: adım 4, 1 resimden 1.
      • Once a network connection has been established, a progress bar will appear underneath the spinning globe.
      • This process is prone to timing out. If you receive an error, try again using a cable connection to reach the internet rather than WiFi. Depending on your model, you may need an adapter to accomplish this.
      FixBot'a Sor
      Yorum Ekle
    5. How to Start Up a Mac in Internet Recovery Mode: adım 5, 1 resimden 1.
      • When Internet Recovery has loaded, you will see the macOS recovery screen.
      FixBot'a Sor
      Yorum Ekle
Sonuç
From the recovery menus, you can restore your data from a Time Machine backup, Reinstall macOS, get help online, and use Disk Utility to format and diagnose problems with any connected storage drives.
85 farklı kişi bu kılavuzu tamamladı.
Taylor Dixon
72.704 İtibar
94 adet Kılavuz yazıldı
44Kılavuz Yorumları
Apparently PowerBook G4 12” does not work for restoral based upon this exercise?
72Yonatan - Yanıt Paylaş
Oh, I’m so sorry! I forgot to specify: internet recovery mode is only available on newer Apple computers. I’ve updated the intro now, sorry for the confusion!
Taylor Dixon - Yanıt Paylaş
So a mid 2009 computer won’t have internet recovery mode?
Carlos Perdomo - Yanıt Paylaş
I bought a Asgard (seems operates from HongKong) 2TB NVME PCIe M.2 SSD that I installed into mackbook pro 15in mid 2015 with sintech adapter for conversion to MacBook AHCI controller. The disk utility does not show this SSD. Later I installed in same way another Sabrent SSD 2TB it worked fine.
What might have gone wrong in the fist SSD. Could that SSD itself faulty or incompatible? any fixes available?
GBish - Yanıt Paylaş
Two main reasons:
- You aren’t pushing deep enough your new ssd drive into the slot. Please reopen your mac, unplug the battery connector and push the new ssd to a fashion position.
- Your are missing the Alt/Option key. Please make the full shorcut: Alt+Shift+R.
Orlando Gomez - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 32
Son 7 gün: 299
Son 30 gün: 1,252
Her zaman: 566,844
