Ana içeriğe geç
How to Strip and Recoat a Cast Iron Skillet
Neye ihtiyacın var
  1. How to Strip and Recoat a Cast Iron Skillet, How to Replace a Cast Iron Skillet Coating: adım 1, 3 resimden 1. How to Strip and Recoat a Cast Iron Skillet, How to Replace a Cast Iron Skillet Coating: adım 1, 3 resimden 2. How to Strip and Recoat a Cast Iron Skillet, How to Replace a Cast Iron Skillet Coating: adım 1, 3 resimden 3.
    • Clamp down opposite sides of the cast iron skillet to a table.
    • Make sure the clamps are secure to avoid injury.
  2. How to Strip and Recoat a Cast Iron Skillet: adım 2, 3 resimden 1. How to Strip and Recoat a Cast Iron Skillet: adım 2, 3 resimden 2. How to Strip and Recoat a Cast Iron Skillet: adım 2, 3 resimden 3.
    • Grind off the black coating of the entire surface to expose the shiny bare metal.
    • Make sure to have on all your safety equipment for this process.
  3. How to Strip and Recoat a Cast Iron Skillet: adım 3, 3 resimden 1. How to Strip and Recoat a Cast Iron Skillet: adım 3, 3 resimden 2. How to Strip and Recoat a Cast Iron Skillet: adım 3, 3 resimden 3.
    • Sand the entire surface of the cast iron skillet to smooth any rough spots left.
  4. How to Strip and Recoat a Cast Iron Skillet: adım 4, 2 resimden 1. How to Strip and Recoat a Cast Iron Skillet: adım 4, 2 resimden 2.
    • Rinse the cast iron skillet with water.
    • Scrub the cast iron skillet with a sponge to remove any excess metal shavings.
  5. How to Strip and Recoat a Cast Iron Skillet: adım 5, 2 resimden 1. How to Strip and Recoat a Cast Iron Skillet: adım 5, 2 resimden 2.
    • Apply an even coating of high heat oil to every part of your cast iron skillet.
  6. How to Strip and Recoat a Cast Iron Skillet: adım 6, 2 resimden 1. How to Strip and Recoat a Cast Iron Skillet: adım 6, 2 resimden 2.
    • Wrap the bottom rack of the oven with aluminum foil.
    • Place the cast iron skillet upside down on the rack above the foil.
    • Bake for 1 hour in a preheated oven of 500°F (260°C) or whatever the highest temperature your oven reaches.
    • Let the cast iron skillet cool completely after baking.
  7. How to Strip and Recoat a Cast Iron Skillet: adım 7, 3 resimden 1. How to Strip and Recoat a Cast Iron Skillet: adım 7, 3 resimden 2. How to Strip and Recoat a Cast Iron Skillet: adım 7, 3 resimden 3.
    • Repeat steps 5 and 6 until a dark black coating has formed.
Sonuç
The finished product will be a dark black that resembles a non-stick coating and has no sticky patches.
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 68
Her zaman: 4,158
