Ana içeriğe geç
How to Take in a Pair of Pants
Neye ihtiyacın var
  1. How to Take in a Pair of Pants, How to Take in a Pair of Pants: adım 1, 1 resimden 1.
    • Measure how much of the pants to take in by pinching the back of the pants until it's no longer loose in size.
    • It may help to do this while wearing the pants.
  2. How to Take in a Pair of Pants: adım 2, 1 resimden 1.
    • On both sides, mark the points of the pants that touch with a white colored pencil.
  3. How to Take in a Pair of Pants: adım 3, 2 resimden 1. How to Take in a Pair of Pants: adım 3, 2 resimden 2.
    • With the white color pencil, starting at your previous markings, draw a diagonal line down and inward towards the middle seam.
  4. How to Take in a Pair of Pants: adım 4, 2 resimden 1. How to Take in a Pair of Pants: adım 4, 2 resimden 2.
    • Take your thread and pass it through the needle. Be sure to tie the end of the thread.
    • Be careful using the needle to avoid pricking yourself.
  5. How to Take in a Pair of Pants: adım 5, 2 resimden 1. How to Take in a Pair of Pants: adım 5, 2 resimden 2.
    • Insert needle with thread attached from the inside of the pants through the top of the waistband.
    • Be sure to pull the thread all the way through.
  6. How to Take in a Pair of Pants: adım 6, 2 resimden 1. How to Take in a Pair of Pants: adım 6, 2 resimden 2.
    • After the needle and thread are pulled through the first point, insert the needle parallel to the first point. Starting from the inside of the pants, poke the needle along the white pencil marks.
  7. How to Take in a Pair of Pants: adım 7, 1 resimden 1.
    • After the second stitch, place the needle and insert it right below the first stitch, this time inserting the needle from outside of the pants.
  8. How to Take in a Pair of Pants: adım 8, 1 resimden 1.
    • Pull the thread taught so it stretches across the two insertion points without being loose.
    • Take the needle from the inside, poke the needle night below the last stitch and continue to pull the thread through.
  9. How to Take in a Pair of Pants: adım 9, 1 resimden 1.
    • Similar to the previous step, take the needle and following the marked line insert the needle from the outside and poke the needle back out from the inside slightly below the previous stitch.
    • Repeat this process, going down the white line you marked, leaving the spaces in between each line of thread to be about half of an inch.
  10. How to Take in a Pair of Pants: adım 10, 2 resimden 1. How to Take in a Pair of Pants: adım 10, 2 resimden 2.
    • Repeat this process until you have made it all the way to the bottom of the white marking.
    • Pull the thread taut to tighten the thread in place.
  11. How to Take in a Pair of Pants: adım 11, 2 resimden 1. How to Take in a Pair of Pants: adım 11, 2 resimden 2.
    • Continue to pull the thread tight until it is hidden within the fabric of the pants.
  12. How to Take in a Pair of Pants: adım 12, 2 resimden 1. How to Take in a Pair of Pants: adım 12, 2 resimden 2.
    • Tuck the last of the thread back into the pants and tie it off within the inside of the pants.
  13. How to Take in a Pair of Pants: adım 13, 2 resimden 1. How to Take in a Pair of Pants: adım 13, 2 resimden 2.
    • Repeat steps 4-12 on the opposite sides of the pants where you marked the second white line.
  14. How to Take in a Pair of Pants: adım 14, 1 resimden 1.
    • Congratulations! You have now altered the size of your pants.
Sonuç
Now your pants should fit your size! To undo this process, use a seam ripper to take out the thread.
Amanda
229 İtibar
1 Kılavuz yazıldı
Ekip
CSU Sacramento, Team 1-11, Laflen Fall 2024 CSU Sacramento, Team 1-11, Laflen Fall 2024 üyesi
CSUSAC-LAFLEN-F24S1G11
2 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 55
