Ana içeriğe geç
How to Tie a Tie: Four-in-Hand
Neye ihtiyacın var
  1. How to Tie a Tie: Four-in-Hand, Preparation: adım 1, 1 resimden 1.
    • Fold the collar of your shirt up.
  2. How to Tie a Tie: Four-in-Hand: adım 2, 1 resimden 1.
    • Wrap the tie around the back of your neck with the narrow end on the left side of your body and the wide end on the right side.
    • The wide end of the tie will be your active end.
    • Note: The narrow end of the tie should be around the height of your belly button or a little higher. It may need to adjusted for personal height.
  3. How to Tie a Tie: Four-in-Hand, Tying: adım 3, 1 resimden 1.
    • Take the active end and cross it over the narrow end, so that it points to the left.
    • Note: be sure that the tie always lays flat so there are no twists in the fabric.
  4. How to Tie a Tie: Four-in-Hand: adım 4, 1 resimden 1.
    • Wrap active end under the narrow end, so that it now points to the right.
  5. How to Tie a Tie: Four-in-Hand: adım 5, 1 resimden 1.
    • Wrap active end over the narrow end, so that it now points to the left.
    • Note: leave this wrap a little loose, as it will be used in step 7.
  6. How to Tie a Tie: Four-in-Hand: adım 6, 1 resimden 1.
    • Pull the active end up through the neck loop, so that it now points up.
  7. How to Tie a Tie: Four-in-Hand: adım 7, 2 resimden 1. How to Tie a Tie: Four-in-Hand: adım 7, 2 resimden 2.
    • Pull the active end down through the wrap you created in step 5 (see second picture).
  8. How to Tie a Tie: Four-in-Hand, Finishing: adım 8, 1 resimden 1.
    • Tighten the knot by pulling down on the active end and up on the knot, adjusting for size and evenness.
  9. How to Tie a Tie: Four-in-Hand: adım 9, 1 resimden 1.
    • Tighten the neck loop by pulling down on the narrow end of the tie and sliding the knot up toward your neck.
  10. How to Tie a Tie: Four-in-Hand: adım 10, 1 resimden 1.
    • Tuck the narrow end of the tie through the keeper loop.
    • Note: if the narrow end is too long, a simple solution lies in tucking the narrow end between two buttons of your shirt.
    • Fold your collar down when the knot is finished.
Sonuç
Congratulations! You've successful tied the Four-in-Hand knot!
5 farklı kişi bu kılavuzu tamamladı.
Electric Warthogs
791 İtibar
3 adet Kılavuz yazıldı
Ekip
The Electric Warthogs The Electric Warthogs üyesi
Community
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 60
Her zaman: 1,784
