Ana içeriğe geç
How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model
Neye ihtiyacın var
  1. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model, How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: adım 1, 3 resimden 1. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model, How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: adım 1, 3 resimden 2. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model, How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: adım 1, 3 resimden 3.
    • Unlock the brake barrel adjusters fasteners with a flathead screwdriver in the clockwise direction.
    • Loosening the fasteners will help to loosen the barrel in Step 2.
  2. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: adım 2, 3 resimden 1. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: adım 2, 3 resimden 2. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: adım 2, 3 resimden 3.
    • Twist in the clockwise direction to tighten the barrel adjusters.
  3. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: adım 3, 2 resimden 1. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: adım 3, 2 resimden 2.
    • While squeezing the bike brake check the distance between the brake handle and the bike handle using a measuring device.
    • It should be about an inch if properly tightened.
    • The second image has a loose brake. The distance is less than an inch, where it should be more than an inch (reference step 8 for the right distance). This indicates that the brake is still loose.
  4. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: adım 4, 2 resimden 1. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: adım 4, 2 resimden 2.
    • Prepare for the next few steps by loosening the bike brake barrel adjuster if it is fully tightened by turning it clockwise a few times.
    • Start by squeezing the brake arms together as much as possible.
  5. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: adım 5, 1 resimden 1.
    • While maintaining the position of the brake arms from Step 4, loosen the bolt that secures the cable clamp using a 5mm Allen Wrench and turn it counter clockwise.
    • Loosen the bolt until the cable can be adjusted easily by hand.
  6. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: adım 6, 2 resimden 1. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: adım 6, 2 resimden 2.
    • While keeping the bike brake arms in the same position as described in Step 5, pull the brake cable to adjust the distance between the brake pads and the wheel.
    • Stop pulling when the brake pads are one or two millimeters away from the wheel.
  7. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: adım 7, 2 resimden 1. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: adım 7, 2 resimden 2.
    • With the brake arms still squeezed together, use the 5 mm Allen wrench to tighten the cable clamp by turning the wrench in a clockwise direction.
  8. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: adım 8, 2 resimden 1. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: adım 8, 2 resimden 2.
    • Tighten the brake barrel adjusters again (as seen in step 2). Do this until the brake handle reaches 25.4 mm from the handle when squeezing.
    • When tightening the brakes, ensure that the brake pads never touch the side of the wheel. If this occurs, then the brake cable was pulled too tight in Step 6 and needs to be loosened.
  9. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: adım 9, 2 resimden 1. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: adım 9, 2 resimden 2.
    • Finally, use the flathead screwdriver to lock the barrel adjuster fastener. Use the screwdriver to twist the fastener in a counterclockwise direction until it is tight.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Emily Arana
169 İtibar
1 Kılavuz yazıldı
Ekip
UCD-MORRIS-S23S1G1 UCD-MORRIS-S23S1G1 üyesi
Community
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 169
