Ana içeriğe geç
How to Tighten the Alternator Belt on your 1990-1993 Honda Accord
Neye ihtiyacın var
  1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord, How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 1, 2 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord, How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 1, 2 resimden 2.
    • Before you begin, make sure your car is off and in park with the emergency brake engaged.
    • Pull the hood release inside the driver's side door.
  2. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 2, 2 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 2, 2 resimden 2.
    • Move to the front of the car.
    • Reach under the hood and release the hood latch.
    • Lift the hood.
  3. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 3, 3 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 3, 3 resimden 2. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 3, 3 resimden 3.
    • Find the prop rod and lift it to prop the hood up securely.
    • Under the hood, it will look like photo 3. Take note of the following components:
    • Battery
    • Alternator
    • Brake System
  4. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 4, 2 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 4, 2 resimden 2.
    • Make sure the car is turned off before disconnecting the battery.
    • Use a socket wrench to loosen the 12 mm bolt on the red battery terminal.
  5. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 5, 2 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 5, 2 resimden 2.
    • Use a socket wrench to loosen the 12 mm bolt on the black battery wire.
  6. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 6, 3 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 6, 3 resimden 2. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 6, 3 resimden 3.
    • Disconnect the negative battery terminal.
    • Disconnect the positive battery terminal.
  7. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 7, 3 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 7, 3 resimden 2. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 7, 3 resimden 3.
    • Disconnect the brake system.
  8. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 8, 3 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 8, 3 resimden 2. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 8, 3 resimden 3.
    • Remove the 10mm bolt securing the brake system using the socket wrench with extension and a long socket.
  9. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 9, 3 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 9, 3 resimden 2. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 9, 3 resimden 3.
    • Use the socket wrench with an extension and a long 10 mm socket to remove the 10 mm bolt securing the brake system on the other side.
  10. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 10, 3 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 10, 3 resimden 2. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 10, 3 resimden 3.
    • Disconnect the black hose.
    • Remove the brake system and set it out of the way.
  11. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 11, 3 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 11, 3 resimden 2. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 11, 3 resimden 3.
    • Use a socket wrench to remove the 14 mm bolt above the top belt.
    • In case it's too stiff, use an extension to create more power.
  12. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 12, 3 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 12, 3 resimden 2. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 12, 3 resimden 3.
    • Remove the 10 mm bolts found under the top part of the alternator using a socket wrench with an extension.
    • The left screw will lower the alternator if unscrewed and raise it when screwed in. The right screw keeps the alternator in place.
  13. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 13, 2 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 13, 2 resimden 2.
    • Lower the alternator by about 3.2 mm.
    • If it's too stiff, use a plastic hammer.
  14. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 14, 3 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 14, 3 resimden 2. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 14, 3 resimden 3.
    • Use a screwdriver or other long object to remove the top belt.
  15. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 15, 3 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 15, 3 resimden 2. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 15, 3 resimden 3.
    • Tighten the 10 mm bolts under the bottom part of the alternator hidden by the black hose (where the red arrow points) using the socket wrench.
    • It's especially important to tighten the right screw/bolt.
  16. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 16, 2 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 16, 2 resimden 2.
    • Check the tightness of the belt with a finger test. If you can press it down, tighten the belt a little more.
    • Continue tightening the screws and checking the belt until there is no slack in the belt.
  17. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 17, 2 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 17, 2 resimden 2.
    • Remove the 10 mm bolts under the top part of the alternator with a socket wrench.
    • This will allow for an easier reinstallation of the top belt.
  18. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 18, 3 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 18, 3 resimden 2. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 18, 3 resimden 3.
    • Reinstall the belt around the bottom and top wheel.
  19. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 19, 3 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 19, 3 resimden 2. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 19, 3 resimden 3.
    • Use the socket wrench with the extension to screw the left and right 10 mm bolt until the belt is tight.
    • This step may be confusing because it is hard to know which direction the bolt needs to move. The bolt will move slightly inwards and that will tighten the belt.
  20. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 20, 2 resimden 1. How to Tighten the Alternator Belt on your 1990-1993 Honda Accord: adım 20, 2 resimden 2.
    • Tighten the top 14 mm bolt with the socket wrench.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 15
Son 30 gün: 56
Her zaman: 273
