Ana içeriğe geç
How to Tighten the Nishiki Aero II Chain
  1. How to Tighten the Nishiki Aero II Chain, How to Tighten the Nishiki Aero II Chain: adım 1, 1 resimden 1.
    • Shift the rear derailleur into its outermost gear, and the front derailleur into its outer gear.
  2. How to Tighten the Nishiki Aero II Chain: adım 2, 3 resimden 1. How to Tighten the Nishiki Aero II Chain: adım 2, 3 resimden 2. How to Tighten the Nishiki Aero II Chain: adım 2, 3 resimden 3.
    • Open the quick-release lever on the rear axle.
    • Quick-release levers are designed to allow you to remove a wheel by hand, with no tools.
    • Continue to loosen the axle by hand until you can freely move the axle in its notch in the rear fork.
  3. How to Tighten the Nishiki Aero II Chain: adım 3, 1 resimden 1.
    • Move the axle farther back along the notch in the fork so that the chain is taught between the cogs.
    • You might want to ask a friend to help you keep everything steady.
    • Be careful when choosing the new position for the axle; make sure that the wheel will be aligned with the frame.
  4. How to Tighten the Nishiki Aero II Chain: adım 4, 1 resimden 1.
    • Now that the axle is placed correctly, re-tighten the axle and re-apply the quick-release as shown in Step 1.
Sonuç
Tobias Elder
113 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-53, Johann Spring 2013 Cal Poly, Team 21-53, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S21G53
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 15
Her zaman: 1,309
