Ana içeriğe geç
How to True Bicycle wheels
Neye ihtiyacın var
  1. How to True Bicycle wheels, How to True Bicycle wheels: adım 1, 2 resimden 1. How to True Bicycle wheels, How to True Bicycle wheels: adım 1, 2 resimden 2.
    • Fit the wheel into the wheel truing stand. It doesn't matter which way the wheel is facing.
    • The wheel should be snug and securely fixed to the stand.
    • Tighten the quick-release nut and lever, making sure that there is no room for the wheel to wiggle in the truing stand.
    FixBot'a Sor
    Yorum Ekle
  2. How to True Bicycle wheels: adım 2, 2 resimden 1. How to True Bicycle wheels: adım 2, 2 resimden 2.
    • Bring the calipers up until the teeth are are about half an inch from the metal rim of the wheel.
    • Start the wheel spinning slowly.
    • Slowly tighten the calipers until they contact the wheel on one side or the other.
    FixBot'a Sor
    Yorum Ekle
  3. How to True Bicycle wheels: adım 3, 2 resimden 1. How to True Bicycle wheels: adım 3, 2 resimden 2.
    • Loosen the spoke nipples that attach to the same side of the wheel that the caliper is touching. At the same time, tighten the spokes that attach to the opposite side of the hub.
    • As a starting point, turn all the spokes half of a turn for each of the spokes near the caliper contact point.
    • In the photo, the red marked spokes are being tightened, and the blue marked spokes are being loosened. This will shift the rim closer to the viewer.
    • Spin the wheel. Tighten the calipers again until they touch the rim on only one side at a time at certain point. Repeat steps 2-3 until the caiplers touch both sides of the rim evenly at every point on the rim.
    FixBot'a Sor
    Yorum Ekle
Sonuç
The wheel should spin without wobbling from side to side or wavering up and down
3 farklı kişi bu kılavuzu tamamladı.
Brett Hartt
132.255 İtibar
144 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
31.535 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 63
Her zaman: 6,304
