Ana içeriğe geç
How to Unclog a Feeding Tube
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
    1. How to Unclog a Feeding Tube, How to Unclog a Feeding Tube: adım 1, 1 resimden 1.
      • Test your tube. Use a 35ml plunger to test your tube, just to confirm it is clogged.
      • Exert a decent amount of force.
      FixBot'a Sor
      Yorum Ekle
    2. How to Unclog a Feeding Tube: adım 2, 1 resimden 1.
      • Massage the tube. Roll the tubing in between your fingers and “massage” it.
      • The clog may be in the external tubing and doing so may break it up.
      FixBot'a Sor
      Yorum Ekle
    3. How to Unclog a Feeding Tube: adım 3, 1 resimden 1.
      • Switch to a smaller plunger. Start using a 10ml plunger.
      • The smaller the plunger, the more pressure is exerted.
      FixBot'a Sor
      Yorum Ekle
    4. How to Unclog a Feeding Tube: adım 4, 1 resimden 1.
      • Flush hot water. Fill your 10ml plunger (and extension tubing, if applicable) with hot water. As hot as you can safely tolerate. Use this to flush your tube.
      FixBot'a Sor
      Yorum Ekle
    5. How to Unclog a Feeding Tube: adım 5, 1 resimden 1.
      • Pulsate. Pulsate the 10ml plunger back and forth, in quick motion. This helps to dismantle the clog.
      FixBot'a Sor
      Yorum Ekle
    6. How to Unclog a Feeding Tube: adım 6, 1 resimden 1.
      • Flush a combination of hot water and meat tenderizer. If your tube is still clogged, fill your 10ml plunger (and extension tubing, if applicable) with a combination of hot water and meat tenderizer.
      • The tenderizer is known to break up clogs.
      FixBot'a Sor
      Yorum Ekle
    7. How to Unclog a Feeding Tube: adım 7, 1 resimden 1.
      • Pulsate. Pulsate the 10ml plunger once again, in a quick motion.
      FixBot'a Sor
      Yorum Ekle
    8. How to Unclog a Feeding Tube: adım 8, 1 resimden 1.
      • Flush Coca-Cola. If your tube is still clogged, fill your 10ml plunger (and extension tubing, if applicable) with Coca-Cola. Flush your tube.
      • Regular coke is the best for breaking up clogs due to its carbonation levels.
      FixBot'a Sor
      Yorum Ekle
    9. How to Unclog a Feeding Tube: adım 9, 1 resimden 1.
      • Pulsate, then let Coca-Cola sit. Pulsate the 10ml plunger once again, in a quick motion. If the clog persists, allow the Coke to sit in your tube.
      • You may leave the Coke in your tube for up to one hour.
      FixBot'a Sor
      Yorum Ekle
    10. How to Unclog a Feeding Tube: adım 10, 1 resimden 1.
      • Test your feeding tube. It should flush easily.
      FixBot'a Sor
      Yorum Ekle
Sonuç
The hope is to successfully unclog the feeding tube at home. Of course, always contact your health care physician in times of concern.
5 farklı kişi bu kılavuzu tamamladı.
Jaquie Beckwith
319 İtibar
1 Kılavuz yazıldı
Ekip
4Kılavuz Yorumları
That is a very good, clear procedure to follow. Those steps are essentially what they might trying the ER. If these steps don't work, the tube probably needs to be replaced.
Sue S.S. - Yanıt Paylaş
This is so clear and helpful. There’s so little available for us tube feeders and this is a great. The Coke tip is fab. You can also use lemonade or any carbonated drink. The main thing to do is not panic, take your time and once the tube is clear , flush well with water.
Michelle - Yanıt Paylaş
I have tried time and time again to unclog my tupe unsuslectfully.hl
Have been told NOT TO USE COKE
Gerald Lacey - Yanıt Paylaş
I have tried warm water
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 55
Son 30 gün: 208
Her zaman: 22,672
