Ana içeriğe geç
How to Unclog a Sink
Neye ihtiyacın var
  1. How to Unclog a Sink, How to Unclog a Sink: adım 1, 3 resimden 1. How to Unclog a Sink, How to Unclog a Sink: adım 1, 3 resimden 2. How to Unclog a Sink, How to Unclog a Sink: adım 1, 3 resimden 3.
    • Begin by filling the sink halfway full with water.
    • Pump the plunger rapidly for 30 seconds.
    • Do NOT break seal between plunger and drain.
    • Repeat this process 4 to 6 times.
    • Wait 20 min before proceeding to the next step. This will allow some debris to flow down the pipes.
  2. How to Unclog a Sink: adım 2, 2 resimden 1. How to Unclog a Sink: adım 2, 2 resimden 2.
    • Place a bucket below the P-trap .
    • The curved white pipe is called the P-trap.
    • These next few steps may get a bit messy. Proceed with caution.
  3. How to Unclog a Sink: adım 3, 3 resimden 1. How to Unclog a Sink: adım 3, 3 resimden 2. How to Unclog a Sink: adım 3, 3 resimden 3.
    • Carefully untwist slip nuts by hand.
    • If you are unable to remove by hand, use a slip joint plier to remove the slip nuts.
    • The nuts at the ends of the P-trap are called slip nuts.
  4. How to Unclog a Sink: adım 4, 3 resimden 1. How to Unclog a Sink: adım 4, 3 resimden 2. How to Unclog a Sink: adım 4, 3 resimden 3.
    • Use a small wire brush to clean the P-trap.
    • You may want to clean the connecting pipes with the wire brush as well.
  5. How to Unclog a Sink: adım 5, 3 resimden 1. How to Unclog a Sink: adım 5, 3 resimden 2. How to Unclog a Sink: adım 5, 3 resimden 3.
    • Carefully rinse the P-trap with hot water.
    • Do NOT rinse the P-trap in the sink you are working on because there is no connecting pipe to catch the water.
  6. How to Unclog a Sink: adım 6, 3 resimden 1. How to Unclog a Sink: adım 6, 3 resimden 2. How to Unclog a Sink: adım 6, 3 resimden 3.
    • Reattach the P-trap.
  7. How to Unclog a Sink: adım 7, 3 resimden 1. How to Unclog a Sink: adım 7, 3 resimden 2. How to Unclog a Sink: adım 7, 3 resimden 3.
    • Pour 1/2 cup of baking soda down the drain.
    • Pour 1/2 cup of distilled white vinegar down the drain.
    • Quickly cover the drain with a drain stopper.
    • This keeps the reaction in the pipes.
  8. How to Unclog a Sink: adım 8, 2 resimden 1. How to Unclog a Sink: adım 8, 2 resimden 2.
    • As soon as the fizzing stops, pour another 1/2 cup of white distilled vinegar down the drain.
    • Cover again with a drain stopper.
    • Let the sink sit for 20 min.
  9. How to Unclog a Sink: adım 9, 3 resimden 1. How to Unclog a Sink: adım 9, 3 resimden 2. How to Unclog a Sink: adım 9, 3 resimden 3.
    • Boil 1 gallon of water with a boiler.
    • The boiler will get hot. Handle with care.
    • Pour the boiling water down the sink to flush out any remaining debris.
Bitiş Çizgisi
5 farklı kişi bu kılavuzu tamamladı.
Daniel Sanchez
299 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-2, Green Fall 2015 Cal Poly, Team 14-2, Green Fall 2015 üyesi
CPSU-GREEN-F15S14G2
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 52
Her zaman: 3,780
