Ana içeriğe geç
How to Unclog a Toilet
Neye ihtiyacın var
  1. How to Unclog a Toilet, How to Unclog a Toilet: adım 1, 1 resimden 1.
    • Before you begin, make sure to use the correct type of plunger:
    • A proper toilet plunger has a funnel-shaped flange extending from the bottom of the rubber cup.
    • A sink plunger just uses a rubber cup, which doesn't form a tight seal inside the toilet bowl.
  2. How to Unclog a Toilet: adım 2, 1 resimden 1.
    • Do not try to continuously flush a clogged toilet. This will likely result in an overflowing toilet bowl.
  3. How to Unclog a Toilet: adım 3, 2 resimden 1. How to Unclog a Toilet: adım 3, 2 resimden 2.
    • If need be, use a pitcher or a cup to add more water to the toilet bowl so that the water level is about half-way full.
    • You'll want to add enough water so that the outer lip of the toilet plunger's rubber cup is completely submerged in order to create a tight seal.
  4. How to Unclog a Toilet: adım 4, 2 resimden 1. How to Unclog a Toilet: adım 4, 2 resimden 2.
    • Insert the toilet plunger into the toilet bowl, making sure that the narrow bell-shaped flange at the end of the plunger is inserted into the drain at the bottom of the toilet bowl.
    • Once inserted, twist the plunger back and forth a couple of times to make sure it's firmly seated at the bottom of the toilet bowl.
  5. How to Unclog a Toilet: adım 5, 2 resimden 1. How to Unclog a Toilet: adım 5, 2 resimden 2.
    • Start by slowly pushing down on the plunger. The inside of the plunger is full of air at first, so a quick downward thrust initially will push that air out quickly and splash water all over you and your bathroom.
    • If the plunger feels a bit stiff, you can run it under hot water to loosen up the rubber.
  6. How to Unclog a Toilet: adım 6, 3 resimden 1. How to Unclog a Toilet: adım 6, 3 resimden 2. How to Unclog a Toilet: adım 6, 3 resimden 3.
    • After making the initial plunge, the plunger should now be completely sealed around the toilet bowl's drain.
    • Next, vigourously force the plunger up and down several times, making sure to keep the plunger sealed to the bottom of the toilet bowl.
    • This method forces water in the drain to push and pull in both directions, eventually loosening the stuck material and unclogging the toilet.
    • After several thrusts, remove the plunger and repeat steps 5 and 6 until the toilet bowl drain clears.
  7. How to Unclog a Toilet: adım 7, 2 resimden 1. How to Unclog a Toilet: adım 7, 2 resimden 2.
    • Once the toilet is unclogged, give the toilet a victory flush to clear out any residual matter left over from the clog.
  8. How to Unclog a Toilet: adım 8, 1 resimden 1.
    • There may be times when a plunger just doesn't get the job done. In that case, a toilet auger may be more useful and persuasive.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Craig Lloyd
35.354 İtibar
82 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 1,029
