Ana içeriğe geç
How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade
Neye ihtiyacın var
Videoya Genel Bakış
  1. How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade, Scan Your Machine for Space and Compatible Hardware: adım 1, 1 resimden 1.
    • I upgraded from a default 8GB RAM to 16GB after installing 2 4GB Memory cards that I bought from Crucial. Scan Your Machine For Compatible Memory to Purchase https://www.crucial.com/
    • Order appropriate compatible parts.
  2. How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade, Turn  off PC and Open the Body: adım 2, 2 resimden 1. How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade, Turn  off PC and Open the Body: adım 2, 2 resimden 2.
    • Turn off your computer and unplug power cords.
    • Slide Open Your PC to install the memory.
  3. How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade, Insert the Memory: adım 3, 2 resimden 1. How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade, Insert the Memory: adım 3, 2 resimden 2.
    • Open your PC and unlock the slots. Insert the memory cards and lock the white end locks.
  4. How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade, If Your System Does Not Recognize the Memory, Take it Out, Restart, and Download the BIOS Upgrade: adım 4, 3 resimden 1. How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade, If Your System Does Not Recognize the Memory, Take it Out, Restart, and Download the BIOS Upgrade: adım 4, 3 resimden 2. How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade, If Your System Does Not Recognize the Memory, Take it Out, Restart, and Download the BIOS Upgrade: adım 4, 3 resimden 3.
    • After I snapped in the new parts, my computer could not fully boot up, so I took the components out, restarted my computer, and downloaded the latest BIOS Upgrade for my PC to a flash drive.
    • Download BIOS Upgrade http://support.asus.com/download
    • Manually find your computer and operating system. Download the latest BIOS Upgrade.
  5. How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade, Run Your BIOS Upgrade: adım 5, 3 resimden 1. How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade, Run Your BIOS Upgrade: adım 5, 3 resimden 2. How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade, Run Your BIOS Upgrade: adım 5, 3 resimden 3.
    • Unzip the downloaded BIOS Upgrade
    • Save the file to a USB
    • Restart your computer. Press DELETE really fast to get to your BIOS settings.
  6. How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade, BIOS Upgrade Screenshots Continued I: adım 6, 3 resimden 1. How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade, BIOS Upgrade Screenshots Continued I: adım 6, 3 resimden 2. How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade, BIOS Upgrade Screenshots Continued I: adım 6, 3 resimden 3.
    • Advanced Settings > Tools > USB > the file you just put into the flash drive
  7. How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade, BIOS Upgrade Screenshots Continued II: adım 7, 3 resimden 1. How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade, BIOS Upgrade Screenshots Continued II: adım 7, 3 resimden 2. How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade, BIOS Upgrade Screenshots Continued II: adım 7, 3 resimden 3.
    • Click 'OK' to run the file in your USB for the BIOS Upgrade.
    • Once you run your BIOS upgrade, you will be directed to a new screen that lists the hardware you are connected to.
    • Press F1 for setup
  8. How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade: adım 8, 1 resimden 1.
    • After you pressed F1 for Setup, you'll be directed to the BIOS settings again. Double check your startup disks are in the right priority for boot. Drag and drop to correct order.
  9. How to Upgrade RAM Memory On Your ASUS CM6870 Desktop PC and Run BIOS Upgrade, Restart And Double Check Your Memory: adım 9, 1 resimden 1.
    • Exit BIOS to restart, and you should be good to go with your optimum memory.
Bitiş Çizgisi
6 farklı kişi bu kılavuzu tamamladı.
lilyxsu
136 İtibar
1 Kılavuz yazıldı
Bir Yorum
Exactly what I was looking for, any chance you have any information on the expected improvement in performance?
Joseph Mullikin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 48
Her zaman: 8,289
