Ana içeriğe geç
How to Upgrade RAM on the M5A97 LE R2.0 Motherboard
Neye ihtiyacın var
  1. How to Upgrade RAM on the M5A97 LE R2.0 Motherboard, RAM: adım 1, 1 resimden 1.
    • Before even opening your computer, it is important you find out the type of RAM you have in your computer. Most modern motherboards have 4 RAM slots, and it is important that each stick of RAM is equal in terms of size and speed so that the computer can operate optimally.
    • To find out what RAM you have in your computer already: press 'control + alt + delete' on your computer while its running, go to the ‘Performance’ bar at the top, select ‘Memory’, and it will display the amount of RAM slots your RAM is using, the speed, and size of the RAM as well.
    • For example, my computer says I have 2 out of 4 slots being used with a speed of 3000 Mhz (the computer will display 3000 Mhz if it’s a 3200 Mhz stick of RAM), and 16 GB of RAM in total. This means I have two 8 GB DDR4 3200 Mhz sticks of RAM in my computer. If I would like to upgrade, I would need to buy another stick of RAM that is the same type.
  2. How to Upgrade RAM on the M5A97 LE R2.0 Motherboard: adım 2, 1 resimden 1.
    • Once you have bought your new stick(s) of RAM and are ready to install it into your computer, select a safe location where you can ground yourself (not on a carpet, preferably hardwood or a flat surface) to perform the fix.
  3. How to Upgrade RAM on the M5A97 LE R2.0 Motherboard: adım 3, 2 resimden 1. How to Upgrade RAM on the M5A97 LE R2.0 Motherboard: adım 3, 2 resimden 2.
    • Remove the two case screws with a Phillips #1 screwdriver.
    • Remove the side panel of the computer.
  4. How to Upgrade RAM on the M5A97 LE R2.0 Motherboard: adım 4, 3 resimden 1. How to Upgrade RAM on the M5A97 LE R2.0 Motherboard: adım 4, 3 resimden 2. How to Upgrade RAM on the M5A97 LE R2.0 Motherboard: adım 4, 3 resimden 3.
    • Make sure the RAM stick lines up correctly with the spacing in the slot. As you can see, it is important you position the RAM facing the right way, otherwise it will not fit correctly and you may damage your new stick(s) of RAM.
    • Take the RAM out of the package, handling only the edges so as not to damage it. Be sure not to touch any of the gold pins on the bottom edge as well.
    • The RAM slots can be found beside the fan. They are highlighted in a light blue – dark blue pattern, and you will already likely see one or two sticks already installed in the slot(s) so you won’t miss it.
  5. How to Upgrade RAM on the M5A97 LE R2.0 Motherboard: adım 5, 3 resimden 1. How to Upgrade RAM on the M5A97 LE R2.0 Motherboard: adım 5, 3 resimden 2. How to Upgrade RAM on the M5A97 LE R2.0 Motherboard: adım 5, 3 resimden 3.
    • Open the side clamps on the edges of the slot you plan to install RAM in.
    • It is recommended that you take your time on this part. Do not be scared to open up the other RAM slots so you can see what it should look like when the RAM stick is in securely. If you open up the slots of the RAM already in, all you have to do is press the RAM back down in the same position in order for the slot to close securely once again.
    • Position the RAM and slowly slide it into the slot. Push it firmly into the slot until it is secure, then close the side clamps around it.
    • There should be a small click as the chip engages.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Joseph Abdelhadi
440 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 29
Son 30 gün: 111
Her zaman: 5,560
