Ana içeriğe geç
How to Use Heat Shrink Tubing
Neye ihtiyacın var
  1. How to Use Heat Shrink Tubing, How to Use Heat Shrink Tubing: adım 1, 1 resimden 1.
    • Measure the diameter of the wire, and then choose a piece of heat shrink that will be large enough to slide onto the wire before heating but will still provide a snug fit once heated. The shrunken diameter should be slightly smaller than the wire's diameter to ensure a tight fit.
    • Heat shrink tubing has a shrink ratio that dictates how much the tubing will shrink once heated, so it's important to choose the right ratio for the job. For example, a length of 2:1 ratio tubing with a diameter of 2 mm will shrink to a diameter of 1 mm.
  2. How to Use Heat Shrink Tubing: adım 2, 2 resimden 1. How to Use Heat Shrink Tubing: adım 2, 2 resimden 2.
    • Measure a length of heat shrink tubing that is slightly longer than the damaged section of wire.
    • Most heat shrink tubing will also shrink longitudinally (around 5-15%), so be sure to give yourself enough tubing to cover the exposed area after heating.
  3. How to Use Heat Shrink Tubing: adım 3, 1 resimden 1.
    • Use a pair of scissors to cut the tubing to the appropriate length.
  4. How to Use Heat Shrink Tubing: adım 4, 2 resimden 1. How to Use Heat Shrink Tubing: adım 4, 2 resimden 2.
    • Slide the tubing onto the wire so that it covers the damaged/exposed section.
  5. How to Use Heat Shrink Tubing: adım 5, 3 resimden 1. How to Use Heat Shrink Tubing: adım 5, 3 resimden 2. How to Use Heat Shrink Tubing: adım 5, 3 resimden 3.
    • Use a heat gun to shrink the tubing.
    • Keep the heat gun moving back and forth along the length of tubing, as staying in one place can damage the wire even further.
    • Continue heating the tubing until it is tightly secured to the wire.
    Est-ce qu’il y a un moyen d’utiliser une gaine thermorétractable sans l’enfiler, par exemple si on a un connecteur non démontable à chaque extrémité, genre câble USB ? Peut on la couper dans le sens de la longueur et la recoller d’une manière ou d’une autre ?
    Auto-cicatrisation ?
    Merci
    yves.debacker - Yanıt
Bitiş Çizgisi
35 farklı kişi bu kılavuzu tamamladı.
Geoff Wacker
89.895 İtibar
89 adet Kılavuz yazıldı
7 Yorum
I find that using a rectangular, one-sided razor blade instead of scissors makes for straighter/cleaner ends, especially vs. larger diameter tubing.
Michal Kotelba - Yanıt
If I don’t have a heat gun, what can I use?
Devnol - Yanıt
Some alternate heat sources for heat-shrink tubing:
* Soldering iron. Hold the iron close to, but not touching the wrap. You may have to apply heat to multiple sides of the wrap, as the convection may not evenly reach all sides of the wrap.
* Cigarette lighter or candle flame. Not a great solution, but works if no better sources are available. If you let the flame touch the wrap, you can end up with soot depsoited on it. Soot will wipe off easily, but it is easy to burn the wrap and wire, even setting the insulation on fire, if you are careless and let the flame sit too long in one spot or for too long.
Ed Eaglehouse - Yanıt
I want to repair a wire but it is attached to a hefty plug one end, and adapter at the other, and the heat shrink I’ve got won’t fit over these. Any suggestions?
Freya Wilson - Yanıt
You would be better off using electrical tape, Heat Shrink is designed to be used on new connections such as 2 wires soldered together and has to be slid on before connecting the wires together or before a larger end connector is attached , it also needs to be the correct size for the wire being covered since it will only shrink to 2 or 3 times its original size,
In your case you would have to cut the cable, slip on the heat shrink and then solder the wires back together before using the heat shrink to cover the bare wires or you could just use a shielded connector designed to connect cables together and forget the heat shrink
simon Smith -
@Freya Wilson
You may have to cut off one of those connections and replace it with a new one after adding heat shrink to the wires.
Vladislav - Yanıt
Thank you. It was helpful.
rezvan khaki pour - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 28
Son 7 gün: 121
Son 30 gün: 592
Her zaman: 67,308
