Ana içeriğe geç
How to Use the Anti-Static Wrist Strap
Neye ihtiyacın var
  1. How to Use the Anti-Static Wrist Strap, Remove any jewelry: adım 1, 2 resimden 1. How to Use the Anti-Static Wrist Strap, Remove any jewelry: adım 1, 2 resimden 2.
    • Before you begin, remove any jewelry from your wrist and fingers.
  2. How to Use the Anti-Static Wrist Strap, Adjust the strap: adım 2, 2 resimden 1. How to Use the Anti-Static Wrist Strap, Adjust the strap: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    $7.16
    • The anti-static strap should be adjusted to fit snugly on your wrist.
    • Pull up on the looped end of the strap to disengage the plastic lock.
  3. How to Use the Anti-Static Wrist Strap: adım 3, 2 resimden 1. How to Use the Anti-Static Wrist Strap: adım 3, 2 resimden 2.
    • To tighten the strap, pull the looped end away from the plastic slide.
  4. How to Use the Anti-Static Wrist Strap: adım 4, 2 resimden 1. How to Use the Anti-Static Wrist Strap: adım 4, 2 resimden 2.
    • To loosen the strap, pull the main part of the band away from the plastic slide.
    • Re-engage the plastic lock before continuing.
  5. How to Use the Anti-Static Wrist Strap: adım 5, 2 resimden 1. How to Use the Anti-Static Wrist Strap: adım 5, 2 resimden 2.
    • Slide the strap over your hand and secure it to your wrist.
    • If the strap is still too loose or tight, you can adjust it while it's on your wrist.
  6. How to Use the Anti-Static Wrist Strap: adım 6, 2 resimden 1. How to Use the Anti-Static Wrist Strap: adım 6, 2 resimden 2.
    • Attach the metal clip to one of the grounding nodes on an Anti-Static Mat or a grounded metal surface.
  7. How to Use the Anti-Static Wrist Strap: adım 7, 1 resimden 1.
    • You're now ready to repair.
    • During your repair, be mindful of the strap's cable, as stretching it too far can cause the clip to unsnap.
Sonuç
For other general electronics skills guides, click here.
46 farklı kişi bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
212.530 İtibar
1.039 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.605 adet Kılavuz yazıldı
7Kılavuz Yorumları
J'ai un doute…
Retirer tout bijou/montre/whatever, mais uniquement sur la main où l'on met le bracelet (ce qui me paraît logique) ou bien des deux mains ?
Yacou - Yanıt
peut ton se connecter direct ex: sur une prise éléctrique avec l'embout terre de la prise
Lucka Lellig - Yanıt
Bonjour @luckalellig non, ceci est fortement déconseillé !! Le courant des prises électriques est trop fort et risquerait de vous électrocuter.
Claire Miesch -
non la terre pas ce branche au pole positif et négatif
Si vous êtes sûre que votre prise est réellement reliée à la terre (ce n'est souvent pas le cas dans les immeubles anciens, ils peuvent une prise de terre reliée à rien) oui la fiche terre (la fiche qui sort de la prise, surtout pas les trous qui sont la phase et le neutre et qui pourraient vous électrocuter - je précise car la réponse précédente semble confondre) sera parfaite.
Marcanpilami -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 43
Son 7 gün: 342
Son 30 gün: 1,270
Her zaman: 58,669
