Ana içeriğe geç
How to Winterize Sprinkler System
  1. How to Winterize Sprinkler System, How to Winterize Sprinkler System: adım 1, 2 resimden 1. How to Winterize Sprinkler System, How to Winterize Sprinkler System: adım 1, 2 resimden 2.
    • Shut the water supply off to the irrigation system. (usually found in the utility room or basement)
  2. How to Winterize Sprinkler System: adım 2, 1 resimden 1.
    • Obtain an air compressor. (you can rent one from the local Home Depot)
  3. How to Winterize Sprinkler System: adım 3, 3 resimden 1. How to Winterize Sprinkler System: adım 3, 3 resimden 2. How to Winterize Sprinkler System: adım 3, 3 resimden 3.
    • Connect a hose to the compressor, and one to the water line (in basement).
  4. How to Winterize Sprinkler System: adım 4, 1 resimden 1.
    • Turn the compressor on.
  5. How to Winterize Sprinkler System: adım 5, 1 resimden 1.
    • Start manually turning on each station of the system one by one.
  6. How to Winterize Sprinkler System: adım 6, 1 resimden 1.
    • Let the air blow the water out for about 2 minutes per station.
  7. How to Winterize Sprinkler System: adım 7, 3 resimden 1. How to Winterize Sprinkler System: adım 7, 3 resimden 2. How to Winterize Sprinkler System: adım 7, 3 resimden 3.
    • Unplug the hose from the compressor and the water line.
  8. How to Winterize Sprinkler System: adım 8, 2 resimden 1. How to Winterize Sprinkler System: adım 8, 2 resimden 2.
    • Turn the air compressor off and then turn the sprinkler system off from the control panel outside.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 640
