Ana içeriğe geç
How to adjust Nishiki Aero II Brake Cable Tension
Neye ihtiyacın var
  1. How to adjust Nishiki Aero II Brake Cable Tension, How to adjust Nishiki Aero II Brake Cable Tension: adım 1, 1 resimden 1.
    • Use the two wrenches to loosen the nut that holds the brake cable to the braking mechanism. Grip the nut with one wrench, then grip the bolt (on the other side) with the second wrench.
    • You might want to enlist a friend to hold on to the end of the cable for you so it doesn't fall off when you loosen the nut that holds it down.
    • In this picture we use pliers and an adjustable crescent wrench in place of the 9mm wrenches that would be ideal for that bolt. However, anything that can grip and turn the bolt will work just fine.
  2. How to adjust Nishiki Aero II Brake Cable Tension: adım 2, 1 resimden 1.
    • Now that the nut is loosened, pull the cable tighter or looser to adjust the resting state of the brake clamp.
    • Adjust the tension so that the brake pads are about 1 to 2 mm from the rim of the wheel.
    • When you are done, firmly tighten the nut that you loosened in the previous step.
  3. How to adjust Nishiki Aero II Brake Cable Tension: adım 3, 1 resimden 1.
    • Afterwards, you can fine-tune the adjustment by tightening or loosening the barrel adjuster located about 7 inches above the brake levers.
Sonuç
Now, your brakes should be all tuned up and ready to ride.
Tobias Elder
113 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-53, Johann Spring 2013 Cal Poly, Team 21-53, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S21G53
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 2,634
