Ana içeriğe geç
How to adjust Razor A steering column
  1. How to adjust Razor A steering column, How to adjust Razor A steering column: adım 1, 2 resimden 1. How to adjust Razor A steering column, How to adjust Razor A steering column: adım 1, 2 resimden 2.
    • Locate the tightening assembly. The tightening assembly consists of:
    • An upper nut
    • A lower nut
    FixBot'a Sor
    Yorum Ekle
  2. How to adjust Razor A steering column: adım 2, 1 resimden 1.
    • This step refers to clockwise and counterclockwise rotation. This is as viewed from the top.
    • If loosening the steering column, follow these steps:
    • Turn the upper nut counterclockwise.
    • Turn the lower nut counterclockwise until it is tight against the upper nut.
    • If the steering column is still too tight, repeat the above two steps until reaching the desired steering column looseness.
    • If tightening the steering column, follow these steps:
    • Turn the lower nut clockwise until reaching the desired steering column tightness.
    • Turn the upper nut clockwise until it is tight against the lower nut.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
Jordyn
565 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-13, Amido Fall 2012 Cal Poly, Team 9-13, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G13
4 Üyeler
10 adet Kılavuz yazıldı
8Kılavuz Yorumları
what move it with your hands? - didn't help
Heather McCasland - Yanıt Paylaş
I couldn't turn this by hand. not sure who writes this advice. trying a pipe wrench.
jmackenzie1234 - Yanıt Paylaş
Thanks you! Why doesn't the owners manual have this?
Jessica - Yanıt Paylaş
Thanks for the instructions. They helped me fix my son’s scooter.
That Dude - Yanıt Paylaş
Thank you for showing the way how to adjust Razor scooter. This instruction help me to adjust my scooter.
Jessie Allen - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 21
Son 30 gün: 101
Her zaman: 44,088
