Giriş
If your brakes are slowing you down too fast or not fast enough, this guide can help remedy this problem.
Neye ihtiyacın var
While holding onto the brake cable, unscrew the screw that holds the brake cable in place using a 5mm allen wrench.
You may need to repeat this process until your desired tension is achieved (trial and error).
