Ana içeriğe geç
How to adjust Triace A310 Brake Cable
Neye ihtiyacın var
  1. How to adjust Triace A310 Brake Cable, How to adjust Triace A310 Brake Cable: adım 1, 2 resimden 1. How to adjust Triace A310 Brake Cable, How to adjust Triace A310 Brake Cable: adım 1, 2 resimden 2.
    • While holding onto the brake cable, unscrew the screw that holds the brake cable in place using a 5mm allen wrench.
  2. How to adjust Triace A310 Brake Cable: adım 2, 1 resimden 1.
    • If you need to loosen your brakes, pull up on the arm while holding the brake cable in place.
    • To tighten your brakes follow the above step, except push down on the arm instead of pulling up.
  3. How to adjust Triace A310 Brake Cable: adım 3, 1 resimden 1.
    • Tighten the screw on the desired location along the cable with the same 5mm allen wrench.
Sonuç
You may need to repeat this process until your desired tension is achieved (trial and error).
Ben Hartinger
340 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-37, Maness Winter 2014 Cal Poly, Team 1-37, Maness Winter 2014 üyesi
CPSU-MANESS-W14S1G37
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 297
