Neye ihtiyacın var
Use Provided M3 Bolts to attach wheel mounting plate to the wheel hub.
If using 63xx motors use a masking tape to prevent nuts from falling from motor mounting plate.
Attach the plate and use 4 x M3 bolts to attach motor plate to the motors
Use Loctite 648 to secure grub screws inside the motor gear to prevent loosening from vibrations.
Use provided 4 x M3 bolts to attach motor (with motor mount adapter if use)
Use 5 x M4 bolts to attach wheel gear to the wheel hub for gear meshing.
Attach wheel to the hanger and lower down motor to prepare gear meshing.
If wheel gear one side is pulled in or further than other sides check wheel hub bolts probably one bolt is more tighten than others or otherwise
If wheel gear is more inside than motor gear use washers provided to pull wheel gear away from baseplate
Loosen up motor bolts so that motor gear would press wheel gear.
Use sheet of paper to drive it through wheel gear and motor gear. Spin wheel to push paper through the gears
After meshing is good tighten motor bolts
Tighten motor bolts to secure motor in correct position
Remove wheel from wheel gear
Use grease to lubricate gears.
Put the plastic lid with stainless steel plate on top of it and tighten all M2.5 bolts
Lubricate V-Ring using grease on ID and on the flap. Mount the V-Ring on top of wheel gear
Do a test spin on the bench to make sure everything is fine and sounds okay
On the first test ride start by slowly accelerating and slowly braking to make sure everything is working fine.
If there is some minor vibration happening at specific RPM it can be some misbalance in wheel/gears which should disappear after gears sit down in their place.
To disassembly gear drive, follow these instructions in reverse order.
