Neye ihtiyacın var
Install 4 x M2.5 bolts through the baseplate to hanger hub.
Cut the motor axle to the 20mm length from the baseplate.
Apply retaining compound like (Loctite 648) to keyway and install in the keyway
Attach stainless steel plate to the motor
Tighten M2 grub screws on motor gear to secure motor gear on axle.
Attach wheel gear using 5xM3 bolts to wheel hub for meshing gears
Add brass washer to axle before mounting wheel hub.
Attach wheel hub to the hanger and lower down motor to prepare gear meshing.
Loosen up motor bolts so that motor gear would press wheel gear.
Use sheet of paper to drive it through wheel gear and motor gear. Spin wheel to push paper through the gears
After meshing is good tighten motor bolts
Remove wheel gear from wheel hub
Put wheel gear into the cover and attach V-ring on the wheel gear.
It is good time to apply grease to the gears
Use 6xM2.5 bolts to attach motor cover to baseplate
Put wheel hub on the axle again
Use 5xM3 bolts to attach wheel hub back to wheel gear.
Do a test spin on the bench to make sure everything is fine and sounds okay
On the first test ride start by slowly accelerating and slowly braking to make sure everything is working fine.
If there is some minor vibration happening at specific RPM it can be some misbalance in wheel/gears which should disappear after gears sit down in their place.
To disassembly gear drive, follow these instructions in reverse order.
