Ana içeriğe geç
How to bleed the Stroker Trail
Neye ihtiyacın var
  1. How to bleed the Stroker Trail, Bleed the Stroker Trail: adım 1, 1 resimden 1.
    • For easier handling, mount your bike into a bike stand.
    • Remove the rear wheel.
  2. How to bleed the Stroker Trail: adım 2, 2 resimden 1. How to bleed the Stroker Trail: adım 2, 2 resimden 2.
    • Remove the brake pads from the brake caliper.
    • Carefully push back the pistons with a flathead screwdriver.
  3. How to bleed the Stroker Trail: adım 3, 2 resimden 1. How to bleed the Stroker Trail: adım 3, 2 resimden 2.
    • Adjust the braking lever to a 45° angle and remove the bleeding screw.
    • Fill up a quarter of the bleeding syringe with DOT 5.1 brake fluid. Hold the syringe upright, cover the tip with a shop towel, and gently depress the plunger to purge any air bubbles from the syringe.
    • Make sure there are no bubbles that can get into the system during the bleeding procedure.
  4. How to bleed the Stroker Trail: adım 4, 1 resimden 1.
    • Fill up three quarters of the second bleeding syringe with DOT 5.1 brake fluid. Hold the syringe upright, cover the tip with a shop towel, and gently depress the plunger to purge any air bubbles from the syringe. Mount the second syringe to the braking lever.
    • On the caliper side install the hose on the bleeding nipple, then open the nipple 1/2 turn.
    • Assure for another time that there are no air bubbles. You want to avoid having them in your brake.
  5. How to bleed the Stroker Trail: adım 5, 3 resimden 1. How to bleed the Stroker Trail: adım 5, 3 resimden 2. How to bleed the Stroker Trail: adım 5, 3 resimden 3.
    • Push the syringe on the caliper. The piston of the lever mounted syringe will come out.
    • Always leave some fluid in the syringe to prevent air from entering the system.
    • Repeat the process on the lever mounted syringe until there are no more air bubbles or there is no more dirty liquid coming out of the system.
    • If necessary, remove the syringes and re-fill them with fresh liquid and repeat the process.
  6. How to bleed the Stroker Trail: adım 6, 1 resimden 1.
    • When done, tighten the bleeding nipple and remove the hose from the caliper.
    • Pull the lever a few times and let it snap.
    • Afterwards push the piston of the lever syringe to make sure that the system is filled completely.
  7. How to bleed the Stroker Trail: adım 7, 2 resimden 1. How to bleed the Stroker Trail: adım 7, 2 resimden 2.
    • Remove the syringe from the braking lever and install the bleeding screw back to the lever.
    • Clean up the lever/caliper with disc brake-cleaner and re-install the brake pads
Sonuç
To reassemble your bike, follow these instructions in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
129.498 İtibar
189 adet Kılavuz yazıldı
Ekip
3Kılavuz Yorumları
Und warum tritt an bremszylinder an der Entlüftung schraube bremsflüssigkeit aus?
Jörg Stalleicken - Yanıt
wir haben alles so gemacht, wie beschrieben, aber es tritt am entlüftungsnippel Öl aus und Luft????
Jörg Stalleicken -
Bei welchem Schritt tritt denn die Bremsflüssigkeit am Entlüftungsnippel aus?
Grundsätzlich ist es normal, dass sich während dem Entlüftungsprozess ein wenig Bremsflüssigkeit am Entlüftungsnippel sammeln kann.
Wichtig ist, dass die Entlüftungsschraube während dem Entlüften nur minimal geöffnet wird, sodass die Flüssigkeit hindurch in das System gedrückt werden kann.
Dennis -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 16,034
