Ana içeriğe geç
How to change Tool for DeepAccess
Neye ihtiyacın var
  1. How to change Tool for DeepAccess, How to change Tool for DeepAccess: adım 1, 1 resimden 1.
    • Prepare Tools and replacement parts.
  2. How to change Tool for DeepAccess, Remove wedge from transducer: adım 2, 3 resimden 1. How to change Tool for DeepAccess, Remove wedge from transducer: adım 2, 3 resimden 2. How to change Tool for DeepAccess, Remove wedge from transducer: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Grab wegdge with tweezers
    • Loosen the screw. (while holding the wedge)
    • Get rid of the copper screw. To NOT use it more than once
  3. How to change Tool for DeepAccess, Place the new wedge in the transducer.: adım 3, 3 resimden 1. How to change Tool for DeepAccess, Place the new wedge in the transducer.: adım 3, 3 resimden 2. How to change Tool for DeepAccess, Place the new wedge in the transducer.: adım 3, 3 resimden 3.
    • Put the wedge in the tranducer from below.
    • Take care, that the Tool Top is flush with the Transducer surface
    • Correct Placement. Tool is flush with transducer.
    • Incorrect Placement. tool is too high.
  4. How to change Tool for DeepAccess, Fasten the copper screw: adım 4, 2 resimden 1. How to change Tool for DeepAccess, Fasten the copper screw: adım 4, 2 resimden 2.
    • Fasten the screw lightly
    • Tighten the screw just so the wedge does not slip out of the tranducer.
    • in case of appliying too much torque. Use a new screw and get rid of the old one.
  5. How to change Tool for DeepAccess, Adjust wedge heigth with setting gauge: adım 5, 3 resimden 1. How to change Tool for DeepAccess, Adjust wedge heigth with setting gauge: adım 5, 3 resimden 2. How to change Tool for DeepAccess, Adjust wedge heigth with setting gauge: adım 5, 3 resimden 3.
    • Place gauge below Tool
    • Loosen the screw so the wedge slides onto the gauge Lever.
    • Lift the gauge up until in contact with the transducer horn.
    • Now the Tool-Top should be flush with the Transducer-Horn
    • Tighten the screw with the torque- wrench
    • Use Torque wrench with 18cN limitation
    • Use tweezers to push the wire down the wire hole, until it Ends some cm below the tool wedge.
    • Use scissors to cut the (contaminated) Wire down to a length of about 1cm below wedge end.
  6. How to change Tool for DeepAccess, Thread Wire through Wedge-hole: adım 7, 3 resimden 1. How to change Tool for DeepAccess, Thread Wire through Wedge-hole: adım 7, 3 resimden 2. How to change Tool for DeepAccess, Thread Wire through Wedge-hole: adım 7, 3 resimden 3.
    • Use tweezers to thread the wire through the hole at the end of the wedge.
    • Afet threading pull the wire some cm through the hole.
Sonuç
Hans Panz
289 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 142
