Ana içeriğe geç
How to change the oil and replace the oil filter in a Suzuki DR650 SE
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
    • Remove oil drain plug and let all oil drain from the engine. Now remove oil filter cover and take out the old filter.
    • Clean out the oil filter reservoir and put in the new oil filter. Replace the filter cover and screw back on tightly. Also replace the oil drain plug.
    • Remove the oil cap and use your funnel to pour in the oil. Watch the glass oil fill level to see how much has been put in. Once full, put the oil cap back on. (2.5 quarts with oil filter, 2.4 w/o filter.)
    • Now that everything is replaced, start the bike up to make sure you have no leaks and see that everything is running smoothly.
Sonuç
Detailed guide pictures will be added later. Until then, here is a video guide: http://www.youtube.com/watch?v=GHj3GjUlx...
2 farklı kişi bu kılavuzu tamamladı.
Ryan
161 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-18, Donnelly Fall 2014 USF Tampa, Team 1-18, Donnelly Fall 2014 üyesi
USFT-DONNELLY-F14S1G18
1 Üye
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 190
