Ana içeriğe geç
How to check or clean Samsung DVD-P230 buttons
Neye ihtiyacın var
  1. How to check or clean Samsung DVD-P230 buttons, Outer Cover & Faceplate: adım 1, 3 resimden 1. How to check or clean Samsung DVD-P230 buttons, Outer Cover & Faceplate: adım 1, 3 resimden 2. How to check or clean Samsung DVD-P230 buttons, Outer Cover & Faceplate: adım 1, 3 resimden 3.
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. How to check or clean Samsung DVD-P230 buttons: adım 2, 1 resimden 1.
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. How to check or clean Samsung DVD-P230 buttons: adım 3, 1 resimden 1.
    • Unscrew the 3 screws in the back.
  4. How to check or clean Samsung DVD-P230 buttons: adım 4, 2 resimden 1. How to check or clean Samsung DVD-P230 buttons: adım 4, 2 resimden 2.
    • Pull the outer case upward and then towards you.
  5. How to check or clean Samsung DVD-P230 buttons: adım 5, 3 resimden 1. How to check or clean Samsung DVD-P230 buttons: adım 5, 3 resimden 2. How to check or clean Samsung DVD-P230 buttons: adım 5, 3 resimden 3.
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. How to check or clean Samsung DVD-P230 buttons: adım 6, 2 resimden 1. How to check or clean Samsung DVD-P230 buttons: adım 6, 2 resimden 2.
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  7. How to check or clean Samsung DVD-P230 buttons, Power Cord: adım 7, 3 resimden 1. How to check or clean Samsung DVD-P230 buttons, Power Cord: adım 7, 3 resimden 2. How to check or clean Samsung DVD-P230 buttons, Power Cord: adım 7, 3 resimden 3.
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  8. How to check or clean Samsung DVD-P230 buttons, Tray: adım 8, 3 resimden 1. How to check or clean Samsung DVD-P230 buttons, Tray: adım 8, 3 resimden 2. How to check or clean Samsung DVD-P230 buttons, Tray: adım 8, 3 resimden 3.
    • Remove the three screws holding in the DVD tray
  9. How to check or clean Samsung DVD-P230 buttons: adım 9, 2 resimden 1. How to check or clean Samsung DVD-P230 buttons: adım 9, 2 resimden 2.
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  10. How to check or clean Samsung DVD-P230 buttons: adım 10, 2 resimden 1. How to check or clean Samsung DVD-P230 buttons: adım 10, 2 resimden 2.
    • Gently lift the DVD tray off of the motherboard.
  11. How to check or clean Samsung DVD-P230 buttons, How to check or clean Samsung DVD-P230 buttons: adım 11, 1 resimden 1.
    • Use the tweezers to make sure all the buttons aren't stuck.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Mitchell Hart
903 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-30, Regan Winter 2011 Cal Poly, Team 3-30, Regan Winter 2011 üyesi
CPSU-REGAN-W11S3G30
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 1,479
