Ana içeriğe geç
How to clean Lite-On LightScribe SHM-165H6S lens
Neye ihtiyacın var
  1. How to clean Lite-On LightScribe SHM-165H6S lens, Chassis: adım 1, 2 resimden 1. How to clean Lite-On LightScribe SHM-165H6S lens, Chassis: adım 1, 2 resimden 2.
    • Insert an open paper clip into the small hole on the left side of the faceplate.
    • After the tray opens, extend it fully.
  2. How to clean Lite-On LightScribe SHM-165H6S lens: adım 2, 3 resimden 1. How to clean Lite-On LightScribe SHM-165H6S lens: adım 2, 3 resimden 2. How to clean Lite-On LightScribe SHM-165H6S lens: adım 2, 3 resimden 3.
    • Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
  3. How to clean Lite-On LightScribe SHM-165H6S lens: adım 3, 1 resimden 1.
    • Pull the faceplate away from the main chassis.
  4. How to clean Lite-On LightScribe SHM-165H6S lens: adım 4, 1 resimden 1.
    • Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
  5. How to clean Lite-On LightScribe SHM-165H6S lens: adım 5, 2 resimden 1. How to clean Lite-On LightScribe SHM-165H6S lens: adım 5, 2 resimden 2.
    • Lift the top and bottom chassis straight up in order to remove them.
  6. How to clean Lite-On LightScribe SHM-165H6S lens, How to clean Lite-On LightScribe SHM-165H6S lens: adım 6, 2 resimden 1. How to clean Lite-On LightScribe SHM-165H6S lens, How to clean Lite-On LightScribe SHM-165H6S lens: adım 6, 2 resimden 2.
    • Clean the lens.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
aaa
171 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
What is the best fluid for the cleaning step?
lordchickenhawk - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 5,628
