Ana içeriğe geç
How to clean Microtek ScanMaker 5900 glass
Neye ihtiyacın var
  1. How to clean Microtek ScanMaker 5900 glass, Remove serial port connection: adım 1, 3 resimden 1. How to clean Microtek ScanMaker 5900 glass, Remove serial port connection: adım 1, 3 resimden 2. How to clean Microtek ScanMaker 5900 glass, Remove serial port connection: adım 1, 3 resimden 3.
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. How to clean Microtek ScanMaker 5900 glass, Remove Lid: adım 2, 3 resimden 1. How to clean Microtek ScanMaker 5900 glass, Remove Lid: adım 2, 3 resimden 2. How to clean Microtek ScanMaker 5900 glass, Remove Lid: adım 2, 3 resimden 3.
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. How to clean Microtek ScanMaker 5900 glass, Detach plastic latches: adım 3, 3 resimden 1. How to clean Microtek ScanMaker 5900 glass, Detach plastic latches: adım 3, 3 resimden 2. How to clean Microtek ScanMaker 5900 glass, Detach plastic latches: adım 3, 3 resimden 3.
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
  4. How to clean Microtek ScanMaker 5900 glass, Continue latch detachment: adım 4, 3 resimden 1. How to clean Microtek ScanMaker 5900 glass, Continue latch detachment: adım 4, 3 resimden 2. How to clean Microtek ScanMaker 5900 glass, Continue latch detachment: adım 4, 3 resimden 3.
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
  5. How to clean Microtek ScanMaker 5900 glass, Fully remove the upper lid: adım 5, 3 resimden 1. How to clean Microtek ScanMaker 5900 glass, Fully remove the upper lid: adım 5, 3 resimden 2. How to clean Microtek ScanMaker 5900 glass, Fully remove the upper lid: adım 5, 3 resimden 3.
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
  6. How to clean Microtek ScanMaker 5900 glass, How to clean Microtek ScanMaker 5900 glass: adım 6, 1 resimden 1.
    • Using a soft lint-free cloth clean the surface glass of dust, finger prints and other debris.
Sonuç
Steven Shaginyan
39 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-9, Regan Fall 2011 Cal Poly, Team 6-9, Regan Fall 2011 üyesi
CPSU-REGAN-F11S6G9
2 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 2,708
