Ana içeriğe geç
How to clean Non-functoning buttons on remote
Neye ihtiyacın var
  1. How to clean Non-functoning buttons on remote, How to clean Non-functoning buttons on remote: adım 1, 1 resimden 1.
    • For later testing: X marks butttons which still work, O marks buttons that don't.
  2. How to clean Non-functoning buttons on remote: adım 2, 2 resimden 1. How to clean Non-functoning buttons on remote: adım 2, 2 resimden 2.
    • Open battery housing and remove the batteries
    • Remove the screw located in the center of the battery housing
  3. How to clean Non-functoning buttons on remote: adım 3, 1 resimden 1.
    • Top and bottom shell of the remote are held together by 4 latches per side. The most fore and aft ones are located about 1cm from each end
    • Pry them open with a small flat head. If you're carefull that will leave only tiny scratches, but it does take some force
  4. How to clean Non-functoning buttons on remote: adım 4, 2 resimden 1. How to clean Non-functoning buttons on remote: adım 4, 2 resimden 2.
    • Once open, remove the insides and clean them from all the drinks and what not that has been poored over the remote
    • If necessary, add contact spray or alike to the buttom of the rubber buttons
  5. How to clean Non-functoning buttons on remote: adım 5, 1 resimden 1.
    • After cleaning and before full re-assembly, you might want to try if things improved.
    • Put the cicruit board back in, add batteries and put the rubber mats onto the circuit board
    • If the repair worked, you should the red top LED flashing
    • Put it all back together again. (Don't forget the screw in the battery housing.)
    • You might need some new batteries as well
Sonuç
23 farklı kişi bu kılavuzu tamamladı.
andre
1.800 İtibar
4 adet Kılavuz yazıldı
29Kılavuz Yorumları
Having trouble with the latches. Can you explain the technique you used to pry them open?
Thanks!
bob - Yanıt
Hi Bob. Force, brute force. Sorry, I don't have a better advice for you. ;-)
andre -
thanks, I fixed mine using your guide.
surfer - Yanıt
You are a life saver, just fixed my onkyo RC-737m control with this guide... Broken a plastic clip but can't tell when it's back together. Cheers again! Leon
Leon Parsons - Yanıt
Géniaaaaaaaaaaal!
Deux télécommandes dont les boutons du volume ne répondaient plus! Et hop c'est revenu ;-)
Merciiiiiiii
Thierry Paulet - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 27
Son 30 gün: 139
Her zaman: 38,868
