Ana içeriğe geç
How to clean Panasonic SA-HT810V DVD Optical Head
Neye ihtiyacın var
  1. How to clean Panasonic SA-HT810V DVD Optical Head, How to clean Panasonic SA-HT810V DVD Optical Head: adım 1, 3 resimden 1. How to clean Panasonic SA-HT810V DVD Optical Head, How to clean Panasonic SA-HT810V DVD Optical Head: adım 1, 3 resimden 2. How to clean Panasonic SA-HT810V DVD Optical Head, How to clean Panasonic SA-HT810V DVD Optical Head: adım 1, 3 resimden 3.
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Remove the screw that is on the right side of the panel facing you.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
  2. How to clean Panasonic SA-HT810V DVD Optical Head: adım 2, 2 resimden 1. How to clean Panasonic SA-HT810V DVD Optical Head: adım 2, 2 resimden 2.
    • Rotate the device so that the back faces you.
    • With a phillips head screw driver, locate and remove the 12 screws highlighted by the red circles in image one.
  3. How to clean Panasonic SA-HT810V DVD Optical Head: adım 3, 1 resimden 1.
    • Before removing cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. How to clean Panasonic SA-HT810V DVD Optical Head: adım 4, 3 resimden 1. How to clean Panasonic SA-HT810V DVD Optical Head: adım 4, 3 resimden 2. How to clean Panasonic SA-HT810V DVD Optical Head: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Microfiber Cleaning Cloths
    $3.99
    Satın Al
    • Before cleaning DVD lens, make sure that the front of the device is facing towards you.
    • Note that the DVD component of the device is boxed in red.
    • To access the DVD lens, spin the gear circled in image two counter-clockwise until the lens is exposed.
    • Clean the lens by GENTLY rubbing with a microfiber cloth and a cleaning solution of your choice.
Sonuç
Nathan Cheadle
161 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-5, Maness Spring 2010 Cal Poly, Team 16-5, Maness Spring 2010 üyesi
CPSU-MANESS-S10S16G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 2,266
