Ana içeriğe geç
How to clean Samsung SGH-T639 keypad
Neye ihtiyacın var
  1. How to clean Samsung SGH-T639 keypad, Battery: adım 1, 1 resimden 1.
    • Flip the phone over and take off the back cover
    • Note: These images do not contain the back cover or battery of the phone.
  2. How to clean Samsung SGH-T639 keypad: adım 2, 1 resimden 1.
    • Use button to remove battery from the phone.
  3. How to clean Samsung SGH-T639 keypad, Motherboard: adım 3, 3 resimden 1. How to clean Samsung SGH-T639 keypad, Motherboard: adım 3, 3 resimden 2. How to clean Samsung SGH-T639 keypad, Motherboard: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    Satın Al
    • Locate the six (4mm) screws on the back casing of the phone.
    • Unscrew each one using a phillips head #000 screwdriver.
    • Place screws on magnetic mat.
  4. How to clean Samsung SGH-T639 keypad: adım 4, 3 resimden 1. How to clean Samsung SGH-T639 keypad: adım 4, 3 resimden 2. How to clean Samsung SGH-T639 keypad: adım 4, 3 resimden 3.
    • Starting at the top of the phone, carefully insert plastic opening device into the seam.
    • Carefully slide device along the seam and around the corners of the phone until the back is separated from the front.
    • Note: Some force must be exerted. Be careful when taking off panel. Go slow.
    • Note: The volume button may separate from the case, this is normal. It is not broken.
  5. How to clean Samsung SGH-T639 keypad: adım 5, 3 resimden 1. How to clean Samsung SGH-T639 keypad: adım 5, 3 resimden 2. How to clean Samsung SGH-T639 keypad: adım 5, 3 resimden 3.
    • Locate the connection point of black wire running from the microphone to the motherboard.
    • Carefully disconnect the gold connector from the motherboard using tweezers.
  6. How to clean Samsung SGH-T639 keypad: adım 6, 3 resimden 1. How to clean Samsung SGH-T639 keypad: adım 6, 3 resimden 2. How to clean Samsung SGH-T639 keypad: adım 6, 3 resimden 3.
    • Locate the red connector at the top of the motherboard.
    • Carefully lift and remove the connector from the motherboard using tweezers.
  7. How to clean Samsung SGH-T639 keypad: adım 7, 3 resimden 1. How to clean Samsung SGH-T639 keypad: adım 7, 3 resimden 2. How to clean Samsung SGH-T639 keypad: adım 7, 3 resimden 3.
    • Locate the gold connector that connects the screen to the motherboard.
    • Carefully disconnect the connector from the motherboard using tweezers.
  8. How to clean Samsung SGH-T639 keypad: adım 8, 3 resimden 1. How to clean Samsung SGH-T639 keypad: adım 8, 3 resimden 2. How to clean Samsung SGH-T639 keypad: adım 8, 3 resimden 3.
    • Start at the bottom of the motherboard and gently pry it from the back of the cell phone using the plastic opening tool.
    • Lift the motherboard from the cell phone.
  9. How to clean Samsung SGH-T639 keypad: adım 9, 1 resimden 1.
    • Remove the motherboard from the cell phone.
  10. How to clean Samsung SGH-T639 keypad, Keypad: adım 10, 2 resimden 1. How to clean Samsung SGH-T639 keypad, Keypad: adım 10, 2 resimden 2.
    • Locate the two black, rubber tabs near the top of the back of the phone.
    • Locate the one black, rubber tab near the base of the phone.
  11. How to clean Samsung SGH-T639 keypad: adım 11, 3 resimden 1. How to clean Samsung SGH-T639 keypad: adım 11, 3 resimden 2. How to clean Samsung SGH-T639 keypad: adım 11, 3 resimden 3.
    • Using tweezers, pry each of the tabs open.
    • Tuck each tab behind the white notch.
    • By tucking the tabs behind each notch. This allows improves the ease of removing the keypad.
  12. How to clean Samsung SGH-T639 keypad: adım 12, 3 resimden 1. How to clean Samsung SGH-T639 keypad: adım 12, 3 resimden 2. How to clean Samsung SGH-T639 keypad: adım 12, 3 resimden 3.
    • Flip phone over to make the keypad visable.
    • Carefully lift keypad around the edges.
    • Remove keypad from the cell phone.
  13. How to clean Samsung SGH-T639 keypad, How to clean Samsung SGH-T639 keypad: adım 13, 1 resimden 1.
    • Obtain device cleaner and a cleaning pad.
  14. How to clean Samsung SGH-T639 keypad: adım 14, 3 resimden 1. How to clean Samsung SGH-T639 keypad: adım 14, 3 resimden 2. How to clean Samsung SGH-T639 keypad: adım 14, 3 resimden 3.
    • Spray the front of the keypad with device cleaner.
    • Clean front of keypad using cleaning cloth.
  15. How to clean Samsung SGH-T639 keypad: adım 15, 3 resimden 1. How to clean Samsung SGH-T639 keypad: adım 15, 3 resimden 2. How to clean Samsung SGH-T639 keypad: adım 15, 3 resimden 3.
    • Flip keypad over.
    • Spray back of keypad with device cleaner.
    • Clean back of keypad with cleaning cloth.
Sonuç
Yi Ren
801 İtibar
8 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-4, Benson Spring 2014 Clemson, Team 1-4, Benson Spring 2014 üyesi
CLEM-BENSON-S14S1G4
3 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 207
