Ana içeriğe geç
How to Clean and Adjust Direct-Pull Cantilever V Brakes
Neye ihtiyacın var
  1. How to Clean and Adjust Direct-Pull Cantilever V Brakes, How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 1, 3 resimden 1. How to Clean and Adjust Direct-Pull Cantilever V Brakes, How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 1, 3 resimden 2. How to Clean and Adjust Direct-Pull Cantilever V Brakes, How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 1, 3 resimden 3.
    • Squeeze the calipers together, and remove the brake cable.
  2. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 2, 3 resimden 1. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 2, 3 resimden 2. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 2, 3 resimden 3.
    • Loosen the brake caliper bolt, and remove the brake caliper.
  3. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 3, 2 resimden 1. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 3, 2 resimden 2.
    • Inspect the brake pad. If the pad has worn down past the “wear line”, then it needs to be replaced.
  4. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 4, 3 resimden 1. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 4, 3 resimden 2. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 4, 3 resimden 3.
    • Clean and lubricate the parts as necessary before reattaching the caliper arms.
    • Bolt the caliper arms back on while making sure the the pin on the back side of the caliper arm lines back up with the one of the holes in the frame. Each side should be in the same hole.
  5. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 5, 2 resimden 1. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 5, 2 resimden 2.
    • Reattach the brake cable to the calipers.
  6. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 6, 2 resimden 1. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 6, 2 resimden 2.
    • Loosen the brake pad bolt.
  7. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 7, 2 resimden 1. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 7, 2 resimden 2.
    • Get an ordinary piece of paper, and fold it twice over.
    • Place the sheet of paper between the brake pad and the rim in the position shown.
  8. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 8, 3 resimden 1. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 8, 3 resimden 2. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 8, 3 resimden 3.
    • Align the brake pad so that it is flush with the rim, with no part touching the rubber of the tire.
    • Have somebody clamp down very tightly on the brakes.
    • Tighten the brake pad bolt in place.
  9. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 9, 3 resimden 1. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 9, 3 resimden 2. How to Clean and Adjust Direct-Pull Cantilever V Brakes: adım 9, 3 resimden 3.
    • Tighten/loosen the tension adjustment screws on each the caliper arm to adjust the resting distance of each brake pad, so that each pad is equally distant from the rim. Tightening the screw will shift the caliper outward from the bike, loosening it will shift it inward.
    • Tighten/loosen the brake adjuster on the handle bars such that when you clamp down on the brakes, the brake lever stops before hitting the handle bar. This will set the distance between the brake pads and the rim.
    • Tighten the lock nut on the brake adjuster to permanently set its position.
Bitiş Çizgisi
49 farklı kişi bu kılavuzu tamamladı.
Travis Tonder
3.175 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010 üyesi
CPSU-MANESS-F10S5G13
4 Üyeler
17 adet Kılavuz yazıldı
4 Yorum
“what does it mean if the point is red???? “
I believe that is indicating that this step corresponds to an image which highlights a specific step. I saw this two times, in step 4 and step 9. For step 4, it shows the highlight in the second image and for step 9, the highlight is in the first image. It seems that the red bullet point is just to make it easier to map the step to the image.
Hope this helps
Tony - Yanıt
where did you get the brake arms from?
I am looking for full metal ones like that,
Ahmed Varnham - Yanıt
In Deutschland werden diese Bremsen nicht als Cantilever Bremsen bezeichnet, sondern als V-Brakes.
timo_a - Yanıt
If your brakes still feel off, you can make further adjustments using the barrel adjuster or by fine-tuning the cable tension at the anchor bolt.
Bruno John - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 61
Son 30 gün: 245
Her zaman: 113,496
